She has twins, greddy twins that is...
Old Sep 21, 2007 | 12:36 PM
  #721
ttrank's Avatar
Grocery getter
Originally Posted by thelurker29
dont you have to tune it for a specific octange gas..??
ive heard you dont really do much unless its tuned for that gas
You don't have to, especially when you are trying to reduce detonation.
But that being said, I have the map selector switch for my UTEC and made another map with some additional timing put back in. Plus I run more boost with the mixed gas. So I do have a specific tune.
Old Sep 21, 2007 | 12:37 PM
  #722
ttrank's Avatar
Grocery getter
Originally Posted by wa2good
Tim, atleast you dont have to run pure VP C16 ($12 a gallon) like we do all the time in our time attack car.
No kidding!
If I had to run C16 in my daily driver I would have to get another car for most of my driving. That would be crazy.
Old Sep 22, 2007 | 06:18 PM
  #723
kenasaki's Avatar
i want to go either single turbo or tt, but i'm still unsure about maintenance costs. whats involved when running a turbo? how often do you change oils, filters, and do you always have to keep a CLOSE eye on eveything? I'm not that knowledgable with cars in general, heck, i dont even want to change my own oil i'm afraid i might mess things up. whats involved?
Old Sep 22, 2007 | 06:56 PM
  #724
ttrank's Avatar
Grocery getter
Originally Posted by Infinite_636
i want to go either single turbo or tt, but I’m still unsure about maintenance costs. whats involved when running a turbo? how often do you change oils, filters, and do you always have to keep a CLOSE eye on everything? I'm not that knowledgable with cars in general, heck, i dont even want to change my own oil I’m afraid i might mess things up. whats involved?
Here is the short version. This is my opinion…
ST:
Pros: Less work to install and the kits are a bit less too.
Cons: More lag, Less room to grow if you decide to build your motor.
TT:
Pros: Very fast spool, More room for more power (Greddy and APS do, JWT 530bb does not have as much room to grow).
Cons: More money to install.
The TN ST does not have an oil pump but the APS and STS do because the turbo sits too low and can’t return the oil to the motor. This does require more looking after because if it goes out you are SOL.
In general:
Every so often you need to check your oil lines to make sure there are no leaks. I still change my oil every 3k and just check the lines at the same time; it takes about two minutes. There is no other maintenance I do. With my SC I had to do the same thing but I also had to check the belts a lot which was a pain. I'm not sure who started this "turbos take more work than SC" thing but I don't agree and have had both.
With any FI kit you need to keep an eye on your motor with the proper gauges. Turbos need wideband A/F, EGT and boost as where SC should have wideband A/F, oil pressure and boost. IMO you can't ever have enough gauges so in my ideal install I would have A/F, oil press, fuel press, EGT, water temp, oil temp and boost.
Old Sep 22, 2007 | 11:19 PM
  #725
agiacalone's Avatar
Fing awesome for sure! Definately could take out a Corvette. (Although the Z06 would be a test)
Old Sep 22, 2007 | 11:43 PM
  #726
ttrank's Avatar
Grocery getter
Thanks!
As my car sits now I would bet a Z06 would win by a good amount. We'll see after my build.
Old Sep 24, 2007 | 01:08 AM
  #727
maliy06's Avatar
Originally Posted by ttrank
Thanks!
I been at at track and i seen an 02 Z06 with nos ran 12.5 that was his best.
Old Sep 24, 2007 | 01:38 AM
  #728
ttrank's Avatar
Grocery getter
I was talking about the new Z06 with the LS7. My car can run a 12.5 or better as-is.
Old Sep 25, 2007 | 06:13 PM
  #729
ttrank's Avatar
Grocery getter
Smile
I posted these in another thread which is in the picture share section but I thought they would go well here too.
So after my detail I decided to take a few pics.
I know I look like a dork and my garage is a mess. I am getting ready to sell my house and packing so the garage is trashed.
Old Sep 25, 2007 | 06:15 PM
  #730
MIA BlazinVQ's Avatar
brb getting cut
^^clean, clean, clean, clean, and did i say clean?
Old Sep 25, 2007 | 06:24 PM
  #731
ttrank's Avatar
Grocery getter
LMAO at your sig.
Old Sep 25, 2007 | 07:59 PM
  #732
TIRE_SMOKE96's Avatar
holy cow! how did you get your G that mirror finish!
Old Sep 25, 2007 | 08:04 PM
  #733
did I mention I want your volks Tim?
Old Sep 25, 2007 | 08:23 PM
  #734
thelurker29's Avatar
actually the TN single kit does come with an oil pump (walbro)
Old Sep 26, 2007 | 01:39 AM
  #735
ttrank's Avatar
Grocery getter
I don't believe that is true. It comes with a walbro 255 fuel pump but I was not aware of an oil pump. Are you sure?... The turbo sits so high there is no need for one.
