Any "X" owners thinking about boosting?
Old Dec 31, 2006 | 02:27 PM
QuadCam's Avatar
WTF is a "Felcon?" are you referring to an HKS F-Con?
Old Dec 31, 2006 | 03:56 PM
ttrank's Avatar
Grocery getter
Originally Posted by DaveB
IMO, you're walking on egg shells with a boosted 5AT. This tranny just wasn't desiged for that power. Luckily, blowers like the rotex, Vortec, and ATI don't add much torque therefore they won't be as taxing on the tranny as a roots style blower like the Stillen. Regardless, the additional 70-90whp will take it's toll on the clutch packs on the 1-2 and 2-3 shifts.
The stillen is not that hard on the AT. It's boost curve is very linear so it comes on gradually. It just starts early so it feels much stronger down low than the other SC kits which don't start for a while. A turbo or twin-turbo will be much harder because once boost comes on it ramps up very quickly.
Old Dec 31, 2006 | 03:57 PM
ttrank's Avatar
Grocery getter
Don't you know what a Felcon is?!?
ok, neither do I
Old Dec 31, 2006 | 06:11 PM
Xman's Avatar
Yeah mine dumped in 2nd
Old Jan 1, 2007 | 01:04 PM
ma_sha1's Avatar
Urban has 42,000 miles running TT with 430 WHP without VB upgrade.
There was quite a few runnig FI without VB upgrade from this thresd below.
https://g35driver.com/forums/forced-induction/112848-all-fi-without-valve-body-upgeade-report-here.html
I am going to try without first & if I feel any sluggish shifting or bounce
off rev limiter, I'll do the VB upgrade. I just don't see how a 5AT could run 42,000 miles without VB at 420WHp, if the transmission is so weak.
There's got to be somthing else that cause transmission failuire, not just lack of VB upgrade. Also, I am not sure if Level 10 or SGP, which way to go?
Old Jan 2, 2007 | 12:52 PM
G35_TX's Avatar
Same tranny comes in the M45/Q45. And can handle V8 power. I am sure it can handle the boost pretty well to a point.
Old Jan 2, 2007 | 06:47 PM
ma_sha1's Avatar
HKS Supercharged AWD G
I just picked up my car, feel & sounded nice! You can hear the super charger, but quieter than Stillen/Vortech, which I like. Feels stronger than the BMW 335i I test drove recently, much stronger than 07 G I also test drove. That makes me happy.
I have not floored the pedal except just once to see where the AFR would go.
The Shift is still quick, probably due to the 10 wire ground, no lagging for 1-2, 2-3 shift so far. I left it in Auto.
The tranmission tempreture gone up 20 degrees, from 125 before to 145 at highest, which is still well below 175-180 danger zoon, so I think no need for a cooler yet.
Idle gone up by 100, from 700 to now 800, but steady & smooth. Super charger runnig smooth & cool to the touch.
Interestingly, the Engine temp. has gone down just a bit, probably due to the
great amount of cool air coming in.
The AFR went down just a bit, from 14.6 idle to 14.2 idle, WOT wend from 12.7 to 12.2. I wonder if it's considered running lean a bit?
No codes. Everything seems running smooth. Knock on wood, I'll baby it for a few weeks before go testing a 1/4 mile run.
The whole thing weight in ~60lbs, but I took out ~15lbs of stock components, so net weight gain is ~45 lbs. My BBK & Light weight battery also shaved 25lbs from stock, so my front end is now about 20 lb havier than a normal G35x.
Knock on wood, Hope nothing breaks.
Old Jan 2, 2007 | 06:51 PM
KrazyEd's Avatar
Good luck....Looks good. Do you have a intercooler?
Old Jan 2, 2007 | 07:58 PM
ma_sha1's Avatar
HKS Rotrex AWD G
Yes, the HKS Kit comes with a intercooler.
I am selling my carbon fiber Z-tube on teh marketplace incase anyone
interested.
Old Jan 3, 2007 | 05:22 PM
DaveB's Avatar
It's the shifts that are the most taxing on the tranny and with more power, the torque is quite a bit higher. Additional heat from the increase power also hurts things. The power delivery across the curve isn't much an issue unless you have some wild single turbo Supra-like power curve that goes from no power to all power in a matter of 500rpms. BTW, transmissions are rated in torque and not HP.
These trannies are indeed the same ones used in the Q/M, but those V8 motors only make an additional 35-45whp/40wtq over the VQ35. Adding 80-100whp and 60-90wtq will push the limits. The problem could be easily solved by using heavier duty clutch packs (maybe out of the Titan Jatco 5AT).
Old Jan 3, 2007 | 06:25 PM
ma_sha1's Avatar
I do see some posts saying "clutch packs" is more important than VB,
but haven'e seen anybody got one, Who is selling clutch pack upgrades?
Old Jan 3, 2007 | 06:28 PM
Xman's Avatar
Yeah the clutchpacks are a problem. SFR and others are working on beefed up versions. I'll probably beat another tranny to death then just get a total rebuild.
Old Jan 4, 2007 | 07:27 PM
Jeff92se's Avatar
Red Card Crew
One would have to get the tranny rebuilt to put new clutch packs in. The valve body upgrade however can be done with the tranny still in the car. As the VB can be unbolted from the bottom of the tranny?
Old Jan 8, 2009 | 06:46 PM
tiguy99's Avatar
Any updates after one year of use? How's the car performing now? How does it act/perform as a daily driver boosted with the HKS SC?
Old Jun 4, 2009 | 10:19 PM
  #30
gizmo134's Avatar
yeah same question ma sha, hows the tranny holding up?
