Dealer said LSD on '03.5 Sedan 6MT
Old Nov 17, 2003 | 11:21 PM
don1's Avatar
I was just in for service today and asked what it would cost to install the LSD on my '03.5 Sedan 6MT (manufactured Dec02 to be exact). They said according to the parts system and using my VIN number, I already have the LSD. Still don't believe it though, and am going to do more research. Can anyone confirm. I am almost positive my car does not have it.
Old Nov 17, 2003 | 11:39 PM
ryoken's Avatar
Re: Dealer said LSD on '03.5 Sedan 6MT
If you already have one, then that goes against everything we've already been told.. that prior to '04, only 6MT Coupe's get the LSD. It's possible, though, that they started putting LSD's on the last of the '03.5's and didn't mention it to anyone, I suppose.
Old Nov 18, 2003 | 12:11 AM
Gsedan35's Avatar
Your safe in sticking with the your positive it doesn't have it thinking, cause it doesn't. No 03.5 6mt sedan's have limited slip. Only the VDC brake activated slip system, which is NOT a viscious limited slip like the 04 6mt sedans get.
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Custom true dual exhaust
Nismo header (soon)
shodog's Avatar
I have wondered about this. a while back I got pissed at this driver on the way to work. I ended up burning out to a point where the car got a little sideways The next day on the way to work I noticed two burn markes instead of one. Mine is an 3/03 build date. I would be happy to find out that it was really true that it has the LSD
Jim
'03 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Nov 18, 2003 | 12:29 AM
Gster's Avatar
Tell me please tell me 03.5 have LSD. If it is true, thank you Santa.
Old Nov 18, 2003 | 12:45 AM
tod071's Avatar
I've been told that LSD was a NEW feature on the 2004. So, who's telling the truth and who's pulling who's leg?
G35S 6MT
Diamond Graphite/Graphite
Premium Package
Old Nov 18, 2003 | 08:03 AM
blackonblackG's Avatar
you can still have two burn lines without having an lsd. were they even??
Old Nov 18, 2003 | 10:11 AM
Gsedan35's Avatar
Keep dreaming guys, no 03.5 6mt sedan has LSD, not unless you paid the $$$ like I did and have one swapped in. When ever job one occured for the 04 6mt sedan's, that's when the LSD became a reality and not a moment before that. Infiniti's Vin parts system is flat out uncontestably wrong of it says any 03.5 6mt sedan has LSD. You can stop wondering.
6mt sed
Crawford Pleneum
Injen CAI
Cusco sway bars
350Z springs&struts
Nismo header (soon)
Old Nov 18, 2003 | 03:29 PM
pestilence's Avatar
I have a 03.5 G35 Sedan and i have had the dealer verify that there is no hardware LSD on our cars.
They might be referring to LSD with the VDC..but its not the same.
Old Nov 18, 2003 | 05:39 PM
ARoss's Avatar
The test for a limited slip differential is to jack up the rear of the car so both rear tires are off the ground. Put the transmission in neutral and spin one wheel. If the other wheel spins the same direction, then you have limited slip. If it spins the opposite direction, then you don't.
On order: 2004 G35s 6MT Diamond Graphite/Graphite
Old Nov 18, 2003 | 07:01 PM
Gzumcrow's Avatar
<hr></blockquote>
The owner's manual talks about "brake limited slip differential" which I understand to mean if one rear wheel slips, the brake will be applied automatically to that wheel to stop the slip, sending power to the other wheel in the process. Is this somehow quantumly different from a "real" LSD? What is the additional benefit to a true LSD?
'03 G35/6MT Sedan Black/Black
Old Nov 18, 2003 | 07:34 PM
RacerX's Avatar
Having driven both, I can tell you that there is a huge difference, especially in wet weather. If you had the LSD, you'd hardly ever feel a single rear tire break traction and the car start to fishtail. You can floor it in the rain at 40mph without any fear of breaking traction. With no LSD, unless you are very careful with the gas in the rain, you will break a rear tire loose constantly. It completely changes the personality of the car in wet weather. Adding a LSD should be near the top of the list of mods for anyone (not leasing) who does not already have one. And if you're going to spend the money, go for the Kaaz, not the OEM; it's even better.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Nov 19, 2003 | 10:53 AM
3point5SE_Auto's Avatar
ok, then I can go to that dealer and say mine is broke/missing and they will have to replace it right? C'mon it could work
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Old Nov 19, 2003 | 10:55 AM
phdvamp's Avatar
If that works, I want to know which dealer you took it to! [img]/w3timages/icons/wink.gif[/img]
03.5 5AT Sedan
<font color=black> Black on Graphite / Prem / Sport / Aero Package / Winter / Tint </font color=black>
Old Nov 19, 2003 | 08:03 PM
Msedanman's Avatar
O.F. Administrator
All 6M/T and A/T Coupes get the LSD rear differential. Page 5-21 of Coupe manual.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
