What kind of springs will work with the non-suspension?
I was wondering what kind of springs should I get for my 03 sedan. My sedan does not have the sport shocks compared to others. I know alot of people are saying get the 350z revised springs but I've read that it works really well with the sport suspension. I was wondering if anyone made springs for the non-sport suspension without having to sacrifice the original shocks? I also have the m45 sport rims on my car and Bigdady1 told me to use the revised springs but I forgot that his car has the sport shocks. Thanks for the help.
^^ Get new shocks or some lightly used 350z or G35 coupe shocks. Look for someone selling their entire stock suspension setup off their 350z or G35coupe. It will save you a lot of $$$
^They used a none sport for r&d but as someone who had the eibachs the ride was bouncy and there was too much negative camber. Will they work with stock none sport shocks... sure.
So you are saying I can use the unrevised 350z package (springs and shocks) and it would lower my car. I've read some where in the forum that someone said that by using the 350z springs and shocks won't lower the g35 since I think the 350z shocks are shorter than the g35.
I think it's a better buy if you have none sport shocks and you want 350z springs or G35 coupe springs to get the spring and shocks even better if the springs are already mounted on the shocks because it will save yourself or the suspension shop you take your car to a lot of time lowering your car and it's a lot safer for them as well.
Originally Posted by erdog
Perry, what shocks are you using with your pro kits? Did you need a camber kit for the front? rear?
Oh and I was using stock sport shocks with my eibach springs.
Erdog, I haven't updated my signature but I took my eibachs off because I needed a camber kit and the drop was too much of a hassle for day to day driving here in Hawaii... There's a lot of steep driveways uneven pavement and potholes. The Eibachs are just too bouncy and it would cost more to control the springs than to replace them with something more suitable for my driving conditions. I just had 350z/G35 coupe springs put on earlier this week. The drop is about 1/4 to 1/2 an inch higher in the front than my eibachs were and they feel more stable. Once the springs have settled I'll get an alignment and figure out how out of spec my camber and toe is then get a camber/toe kit to correct it if necessary.
Are you still running the OEM front lip on your sedan?? Do you have any rubbing issues with the 350z/coupe spring setup? I may get a lip for my car that is why I am asking.
^ I haven't had any rubbing issues with the lip YET but it's worth having the lip over not having one! Yes I still have my lip. I already start looking at camber kits already so I'll focus on the front instead of the rear. shame the front kit is the more expensive though
Originally Posted by jimmykce1
SPL cost me 549 and 9 dollars shipping to VA.
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
