Jan 11, 2007 | 01:51 PM
My auto Sedan just started presenting a problem. When I first start it, the idle jumps to about 1400 rpm & stays there for about 3 minutes. Pedal pushing does nothing to reset it. When I put it in drive, it wants to roll from a stop when I release the brake. This just started happening this week, so I doubt the idle setting just drifted.
Any ideas what causes this? Would a dirty air filter cause this (K&N)? Should I just adjust the idle & forget about it? (I forgot where the adjusting screw is ).
Reply 0
Jan 11, 2007 | 02:07 PM
Quote: My auto Sedan just started presenting a problem. When I first start it, the idle jumps to about 1400 rpm & stays there for about 3 minutes. Pedal pushing does nothing to reset it. When I put it in drive, it wants to roll from a stop when I release the brake. This just started happening this week, so I doubt the idle setting just drifted.
I'd suggest a power down ECU reset.
Reply 0
Jan 11, 2007 | 03:52 PM
Are you sure its just not your car is cold and trying to warm up. Mine does that all the time when i first start it up and is cold and them once it warms up its fine.
Reply 0
Jan 11, 2007 | 03:56 PM
Quote: Are you sure its just not your car is cold and trying to warm up. Mine does that all the time when i first start it up and is cold and them once it warms up its fine.
+1 ftw
Reply 0
Jan 11, 2007 | 04:28 PM
Come on folks. This isn't my first winter. I have an '04. My post stated it just started this week. It's called a racing idle. Somethings wrong. It even races when I start it after parking it in a lot & returning (still warm). Could a clogged air filter cause this? Am I posting in the wrong section?
Reply 0
Jan 11, 2007 | 04:31 PM
Quote: Come on folks. This isn't my first winter. I have an '04. My post stated it just started this week. It's called a racing idle. Somethings wrong. It even races when I start it after parking it in a lot & returning (still warm). Could a clogged air filter cause this? Am I posting in the wrong section?
have you tried cleaning your throttle body?
Reply 0
Sounds like an airflow sensor issue. I would clean the TB and MAS then do an ECU reset.
Reply 0
Jan 11, 2007 | 04:32 PM
Quote: have you tried cleaning your throttle body?
LOL, same idea, same time!
Reply 0
