Medicine for the mod bug....thinking of dropping my G
Old Jan 24, 2007 | 10:03 PM
  #31
jimmyc13's Avatar
Originally Posted by G35m@
I just finished a 300 mile drive today with 70miles through the Blue Ridge Parkway with the new suspension - car dropped right at 1" on both front and back - I will post pics when I get home.
Pro's -
1. Looks damn good!
2. Less see-saw motion under acceleration and breaking
3. Other G's speed up to look at the car
4. Cornering is vastly improved
5. Car rides pretty much like stock around town and on the highway
Cons
1. Body roll was not reduced as much as I thought it would be - (Hotchkis sways in the garage which I expect will eliminate this problem)
2. OEM non-sport 17's look woefully inedequate.
3. Over uneveven roads the sound and feel are transfered into the cabin at a higher rate over the stock suspension (if that makes sense)
Overall I've very happy with the performace gains and the look of the car - The drop is perfect for making the car look aggressive with out being considered "slammed" - can't wait for the 19's
Sweet! Please post up some picts & closeups!
Old Jan 25, 2007 | 10:02 AM
  #32
Jeff92se's Avatar
Red Card Crew
Originally Posted by S.E.
I've been riding around on my 1" drop for a few days and my already squeaky 03.5 cabin has turned into a nightmare. there are sooooo many new sounds and creaks. Would going with tokico shocks soften it up at all? anything I could do to eliminate some of the noise?
https://g35driver.com/forums/showpos...4&postcount=18
Old Jan 25, 2007 | 10:54 AM
  #33
da mayor's Avatar
I am lowered 2.5 inches and had 19x8.5 rims with 245/40/19 tires with 5 people in the car and no rubbing
lowering was the first mod I usually do now because it looks a lot better and handles well
Old Jan 25, 2007 | 10:57 AM
  #34
ORANGEBSRT's Avatar
I lowered mine on 350z H-techs. Rides better than stock, alignment isn't off, and it looks great.
Old Jan 25, 2007 | 11:15 AM
  #35
ttrank's Avatar
Grocery getter
Cons
The 19's with wider tires will help all the cons except for the road feel. That will get worse with a smaller side wall tire.
Old Jan 25, 2007 | 11:36 AM
  #36
Jeff92se's Avatar
Red Card Crew
I can't see how your alignment could still be in spec using those springs
Old Jan 25, 2007 | 12:45 PM
  #37
jimmyc13's Avatar
How are the H-tech's different than the OEM Z springs?
Old Jan 25, 2007 | 02:30 PM
  #38
ORANGEBSRT's Avatar
well its still good cause I don't need a camber kit. Thats what I'm tryin to say
Old Jan 26, 2007 | 07:55 PM
  #39
jimmyc13's Avatar
I may have found a seller who is selling '04 sedan sport shocks/struts with the z-springs up front & coupe springs for the rear. Can someone confirm that the sedan sport shocks are good to match w/ these springs? The last thing I want to do is buy them & find out 20K later, I need new shocks!
Thanks!
Old Jan 26, 2007 | 07:58 PM
  #40
Jeff92se's Avatar
Red Card Crew
You should be good to go as long as they don't have too many miles on them. The sport sedan shocks are the same as the coupes and are stiffer than the sedan non-sports. This is the exact combo I plan on doing (have the parts) and is a very common combo here. The Z/Coupe springs should have the same rating. They just have diff ride heights.
Old Jan 26, 2007 | 08:06 PM
  #41
da mayor's Avatar
19's w/ the 350z H&R springs.... i have a rwd so if you have an X see neal376 and his car
Old Feb 2, 2007 | 01:16 PM
  #42
jimmyc13's Avatar
I paid $150.00 for the install as I have no room at the house and it was better that the wife not see me doing more work on the car...
Where did you get yours installed?..and was this springs & shocks/struts? I just called to see how much it would cost me @ the stealership & they quoted me a price of $650!? I asked why the price was so high & he said it takes about 6 hrs.....
Is that true!?
Old Feb 2, 2007 | 01:21 PM
  #43
Jeff92se's Avatar
Red Card Crew
Maybe. If the mechanic had a broken arm, was mentally challenged and was wheelchair bound
Even if that price included an alignment, it would be way too much.
Is that true!?
  #44
az1anbeethoven's Avatar
^^damn...$650 will get a whole car crew's suspension installed... most people in so. cali go to "street image" which charges $100 for springs& shocks installed...they only took 45mins-1hr...
Old Feb 2, 2007 | 02:17 PM
  #45
jameyb's Avatar
Is that true!?
NO WAY! It took me about 4 hours, so someone who actually knew what they were doing could do it in 1-2 easily.
