The Air Filter Mod.
Old Jan 27, 2007 | 02:58 PM
SkydiverTilt's Avatar
The Air Filter Mod.
My first engine mod on the car is going to be to replace the air filter assembly with a cone or ram air type.
Who and what works best on installation ease and such on the 2005 Sedan?
I tried to search but it didn't help...mainly because i'm lacking the terminology.
Old Jan 27, 2007 | 03:04 PM
machiavalian's Avatar
I have the 350Z Tube, and the JWT Pop Charger on my G, and i love it sounds great, it was $235 shipped from Everythingg35.com... Good Luck man
Old Jan 27, 2007 | 03:07 PM
brianmfournier's Avatar
I went with the stillen intake. I picked mine up from a fellow member. Mine is a coupe, but it's the same set up
Good luck
Old Jan 27, 2007 | 03:21 PM
This is the exact look i'm going to. Stole from a member who I IM'd about manufacturer. I really like the carbon fiber intake pipe as well.
ttrank's Avatar
Grocery getter
Before I had my TT, I had the Stillen with UTR CF Z-tube.
But your first mod should be a plenum spacer. Better gains than an intake.
Old Jan 27, 2007 | 03:22 PM
Plenum spacer? can you show a picture? how easy/hard is it to install?
Old Jan 27, 2007 | 03:36 PM
jameyb's Avatar
That is a JWT Popcharger. It is very similar to the Stillen with exception of the "box" Stillen utilizes to supposedly prevent engine heatsoak. Run a seach for popcharger and you can find all the info you ever wanted and then some.
In the end, you won't feel any gains from intakes. They are mostly sound and appearance mods. Intakes have historically been one of the most hotly debated items on this forum. If you search you can find a plethera of information.
EDIT - now that i look at it again, it seems that is the Stillen filter with a popcharger heatshield. Stillen filters are red, popchargers are blue if I am not mistaken.
Old Jan 27, 2007 | 04:16 PM
Nice catch, I didn't even notice until you mentioned it
Old Jan 27, 2007 | 04:20 PM
GGRJR's Avatar
For info on the intake spacer check out MmotorDynes website. They have pretty detailed instruction online.
http://www.motordyneengineering.com/manual.asp
They are just one of several manufacturers.
Also check the sticky under intake/ exhaust in the tech section
https://g35driver.com/forums/intake-exhaust/71386-group-install-iso-thermal-gasket.html
Old Jan 27, 2007 | 04:57 PM
Neal376's Avatar
JWT is much louder than the stillen.
but stillen looks more mature/subtle
as you see, i like things color matched
if you get an intake, get a AEM dryflo filter to go with it. Do not purchase a Oil type filter - will only screw up your MAF
Old Jan 27, 2007 | 05:12 PM
ttrank's Avatar
Grocery getter
https://g35driver.com/forums/showthread.php?t=71386
+1
Motordyne rocks!
Old Jan 27, 2007 | 05:21 PM
Neal376's Avatar
crawford ftw
Old Jan 27, 2007 | 05:30 PM
Originally Posted by Neal376
crawford ftw
Crawford +1
Old Jan 27, 2007 | 05:59 PM
IP05G35's Avatar
K&N filters will not screw up your MAF sensor! Only if you over oil the filters when you recharge them will you have problems...
Old Jan 27, 2007 | 06:10 PM
Neal376's Avatar
they screw em up
