03 350Z mid-pipe on 05 sedan?
Old Feb 12, 2007 | 10:29 AM
devster's Avatar
I have an 03 350Z mid-pipe sitting in my garage off of my 350Z. I know that with a 6" extension, it will fit my sedan.
I have read that the 05+ sedan exhaust is already quite good, but I notice there is a big mid-pipe muffler vs the small muffler on the 350Z.
Are they the same internal diameter? If so, I understand the performance gains will be minimal or completely non-existant, but I'll lose a few pounds and change the exhaust tone. Currently, the only thing on the car is the HKS rear pipe/muffler.
Thanks--
Old Feb 12, 2007 | 10:35 AM
Chico's Avatar
save your money. The sound will be slightly (and I mean SLIGHTLY) deeper that you won't really notice the difference. One thing you'll get for sure is the the annoying drone, plus you'll hit the cross brace between the drive shaft and the midpipe (unless you modify it). You will also lose back pressure for sure.
Old Feb 12, 2007 | 10:57 AM
trey.hutcheson's Avatar
I ran a 350z midpipe with extension on my 05 6MT sedan for about 9 months. I did notice a deeper tone, and a little more fuel-burn pop when decelerating. And drone was *marginally* increased. But every one has his own opinion on drone.
I never measured the ID of the exhaust components, but I didn't have any problems getting everything lined up. If you've got it just sitting in your garage, I say go for it.
Old Feb 12, 2007 | 11:17 AM
trey's wife's Avatar
My horns hold up my halo
Ours just bolted right up. No issues with hitting anything, etc. It took no time at all to bolt up and if you have one I would say give it a shot. If you don't like it, you can always go back and you haven't really lost much of anything.
Old Feb 12, 2007 | 11:18 AM
devster's Avatar
Thanks - I think I'll get the extension pipe and give it a shot. It can't hurt.
Old Feb 12, 2007 | 11:20 AM
devster's Avatar
I also have the Y-Pipe. Any difference? Maybe I should just get under my car and check! Hey I am at work.
What about the muffler? Just kidding!
Old Feb 12, 2007 | 11:39 AM
Jason@Riverside's Avatar
One of the main differences will be weight reduction... I dont know the exact amount but getting rid of that huge resonator helps...
I would just wait till you get your hands on a G35 coupe mid-pipe and not mess with the extension...
Old Feb 12, 2007 | 12:02 PM
That would be true on the '03-'04 sedan but not so much on the '05. There is really little difference in the resonator from the '05 sedan and the coupe. If you want the same amount of difference the sedan guys were getting from the coupe midpipe then you are going to need to go to the 350 pipe. If you have an '05 I wouldn't bother with the coupe midpipe and adding the extension would likely cost about the same as his purchasing a coupe midpipe.
Old Feb 12, 2007 | 01:30 PM
G35Papa's Avatar
^Nice avart
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
wuppiedog
Aug 7, 2015 11:16 AM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
