Is it me or it is standard on G's
Old Feb 14, 2007 | 11:17 AM
dunglan7's Avatar
Originally Posted by DieselX
Also sounds like a vacuum leak. Doubt he would get that if he didn't mod though.
All I have is a HKS muffler and a Nismo CAI. Can anyone of those cause the problem?
Old Feb 14, 2007 | 11:59 AM
cato's Avatar
SouthernComfort Moderator
Sounds like our 2000 Maxima when the coil packs needed replacing. When the coil packs go, the idle surges and dies and it idles like crap! Cost around $1000 to have all 6 coil packs replaced.
Old Feb 14, 2007 | 12:05 PM
dunglan7's Avatar
Well that's the thing. When I got in my car today I looked at the idle and it was still. The needle is not jumping around. It looks normal. I still feel like the car is shaking but very little. Nothing unbearable. Also I feel the steering wheel vibrating lightly also.
Old Feb 14, 2007 | 12:42 PM
ttrank's Avatar
Grocery getter
Originally Posted by BigSash
DUDE did you get the fuel hose recall done? If not 10 to 1 that is the culprit.
Why?
The fuel hose recall was because the filler hose could crack and leak over time causing a fire.
I am 99.9% sure it's not a dirty fuel filter, I changed mine when I put in my larger pump and it's huge. After ~45k mine was still perfect.
Old Feb 14, 2007 | 07:49 PM
TIRE_SMOKE96's Avatar
If your engine sounds strong but it feels weak then you need to have you transmission checked. You did say that it shakes. To me that sounds like the torq converter is going bad. Now I am assuming you feel the shaking after you put it in gear and start to move?
Old Feb 14, 2007 | 09:19 PM
Andy77's Avatar
There are many causes and a vacuum leak, mentioned above, is a possibility. With so many possibilities it would pay to get a good diagnosis before replacing expensive parts. Good luck.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
stratous01
Oct 7, 2015 10:19 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
TNRocker
Sep 21, 2015 08:36 AM
