Water leaking in from fresh air vent...
Old Feb 15, 2007 | 08:42 PM
Pirate's Avatar
Every time I wash my car I get water leaking inside by the gas pedal. I'm guessing it's coming through the fresh air vent? Has anyone had this issue or does anyone know how to clean the fresh air vent drains out? Thanks!
Old Feb 20, 2007 | 10:48 PM
Pirate's Avatar
Has anyone else run into this issue? Thanks!
Old Feb 21, 2007 | 01:28 PM
jimmyc13's Avatar
I had this exact problem after getting my remote starter installed...the F'n idiots didn't push the rubber gasket @ the firewall back in place properly...I went to the carwash & my F'n floormats were soaked because of them!
Anyways, to answer your original question, I'm guessing it's that exacty problem...open up your hood & look for a rubber gasket in proximity of the gas pedal location & see if it's loose & push it on hard..... I still have rust @ my gas pedal because of the water that came in.
Good luck & let me know if this is it!
Old Feb 21, 2007 | 01:32 PM
Pirate's Avatar
Thanks for the suggestion - I'll check that tonight and let you know. Thanks again!
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
alessandro
Oct 8, 2015 09:29 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Rhinos7777
Sep 6, 2015 05:36 PM
