Offset
Old Feb 15, 2007 | 10:53 PM
BuckeyeG's Avatar
Offset
Hey Im looking at getting some 19x8 and 19x9 Ggames. I was just wondering what offset i would need. I would like them to be kinda flush if possiable. Im thinking like 40-45 for rears but I just wanna make sure front and back. Also what size rubber should i get ? Thanks
Old Feb 16, 2007 | 12:20 AM
Tunerz_Store's Avatar
for 8" wheel up front get a 35, for 9" wheel in rear get 40.
Old Feb 16, 2007 | 01:21 AM
VQ Hotness's Avatar
Anything around 40-45mm in the rear should be fine. And for rear tire choice i would go straight for 275/30s. Tire choice for the front should be around 235/35s maybe even 30s..
Old Feb 16, 2007 | 01:40 AM
psedog's Avatar
Back in SD**
Are you sure 275 would be right on a 9" wheel? I would've thought 235 or 245. Isn't 275 good for 10" wheels? 275 is almost 11" wide, that would be some serious bulge, right?
Old Feb 16, 2007 | 02:07 AM
245/45 is run on a 8-8.5" wheel, so on a nine you could run a 255, 265 or 275 and be fine.
look at the specs here:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
look at each tire size and it tells you what width wheel is applicable.
Old Feb 16, 2007 | 03:51 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
19x8 +35 235/35/19
19x9 +40 265/35/19
-GP-
Old Feb 16, 2007 | 10:45 AM
VQ Hotness's Avatar
Im on 275/30s on 8.5s and no bulge.
You should be fine, your rim will be half a inch wider then mine. You might be able to bump it up to 35s in the rear.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
