So I found me this 8-speed Skyline in my garage today. Thought I'd take a few pics...
#47
#49
Originally Posted by TunerDad
Would you be kind enough to post another pic that shows off those window vents a bit more? I'd like to get a better view of them.
Thanks
tD
Thanks
tD
There you go. If anybody wants them, make me an offer. They are coming off as soon as I can figure out a way to remove the superglue they are stuck on with without damaging something.
#50
Originally Posted by Grumpy_G
I have two small picture request.
1. Under hood picture. Particularly looking straight down, right behind the radiator. On the US. model, there's an empty spot where something can be mounted. Wondering if it only apply to foreign market.
2. Rear Differential. I believe Australian model have a finned differential housing, where US. gets the plain one. Just wanted to confirm.
Thanks in advance.
BTW, welcome aboard and enjoy your stay.
Thanks in advance.
Diff both front and back.
#52
Originally Posted by Floyds_racing
Sweet ride not to sure about the wood grain! lol its tight thou I would deal with it!
Another reason why I like it is that the finish is smooth and hard so it doesn't scratch anywhere near as easy as the titanium finish round the rest of the console.
#54
Yes the car does have TV hooked up, but Navigation and TV don't work out of Japan. Don't really care about the navigation, but very interested in getting the TV to work(just cause it's there). At the moment all I see is static I've been told cause Japan has their channels on different frequencies. I've pulled apart the dash and found a small tuner box that is wired into the NAV system. It is all OEM.
If anyone can help me with the technicalities of this, please PM me. Cheers!
#55
#56
#57
Originally Posted by wink
180km/h as nearly all JDM cars are speed limited to 180km/h
I know with the old skylines you could get a 280 or 320km kit. Wonder if you can get it for the 03+ models.
#58
#59
Originally Posted by psedog
I know, I used to live there. They also make this anoyying sound when you go above 110ish km. That's an easy fix though .
http://www.nismo.co.jp/products/prod.../interior.html
#60
Originally Posted by da mayor
i want to see that thign on a track w/ a 8 speed tranny
Originally Posted by Nismo G
hm..i have never heard of this..? Lets see some pictures of the paddle shifters. Also a picture of it in 8th gear.
-sean
-sean
If the 8 speed is true, i want one shipped to the US and installed in my car. Then i want the same gearing put in my car as it is now and see if i can get it to 200+ MPH....then the car will prolly blow up.
-sean
-sean
Good luck with that.
It does cruise quite easily at higher than normal speeds.
I will say that the car does not launch well at all, seems to bog down for some reason, even in manual mode(yes vdc is off), but after you are cruising in 5th, drop it down to second and the car is scarily quick. I've driven a number of quick cars previously, but this is definitely up there. Of course this is all seat of the pants and I'll try to justify the feel with some numbers soon. The thing I like most about the engine/trans package is that at no point does it scream like its reaching it's limits. It just purrs whatever I throw at it like it's normal and it's like there is heaps in reserve.
