conical filter JWT install questions
Old Mar 8, 2007 | 05:01 PM
IP05G35's Avatar
OK, when you buy the standalone JWT conical filter, does it fit directly onto the mass air housing? What size is the flange inside diameter of the filter, 3, 3.5 or 4 inch?
Old Mar 8, 2007 | 05:52 PM
Konsole's Avatar
Yes, It will fit the stock MAF pipe thingy. Bolts right on with 4 bolts
Old Mar 8, 2007 | 06:18 PM
IP05G35's Avatar
My real question is, i'm trying to use one of the new Amsoil conicals and wondering what will be needed to install an amsoil conical onto the stock mass air housing?
Old Mar 9, 2007 | 10:20 AM
ttrank's Avatar
Grocery getter
I believe you still need that velocity stack adapter. I know you do with the Stillen.
Old Mar 9, 2007 | 10:31 AM
sloppymax's Avatar
you could use a 3" maf adapter with a 3"amsoil cone. i reused my maf adapter from my maxima and threw a 3" k&n filter on it. i ended up ditching it back for the stock box with the lower resonator plugged and power duct removed but its easy enough. just get a 3" maf adapter, 3" cone filter(whichever length will fit, mine was 5" iirc) and 4 bolts/nuts.
Gookiecrunch
Aug 19, 2015 12:00 PM
EPG35
Aug 16, 2015 04:52 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
