REV light
Old Mar 12, 2007 | 08:43 PM
B~PAIN's Avatar
REV light
I have heard rumors that the point at which it starts to blink can be adjusted in 200 rpm increments. How do i do so? I have an 05 6mt
thanks
Old Mar 12, 2007 | 09:01 PM
BuckeyeG's Avatar
You adjust it buy toggling to it with your trip mileage on your speedo.
Old Mar 12, 2007 | 09:32 PM
MRMEATY's Avatar
It is in the owners manual if you have one. If not you use the trip button. The rev light will blink 200-300rpms before it hits the rpm point you set, then the rev light stays on solid when you hit the set point.
Old Mar 12, 2007 | 10:03 PM
ttrank's Avatar
Grocery getter
Too bad the 03/04's don't have this.
Old Mar 12, 2007 | 10:54 PM
izmir41500's Avatar
G35driver Addict
push the trip button in your gauge cluster until you get to the rpm setting. default is at 8k if you hold the button down it should start blinking. then you push the trip button until you set the rpm you want. the light will blink 500 rpm before the set point and remain solid afterwards. unfortunately, in 6th gear, the rev light will still be active. meaning if you're cruising at 3k rpm and you have it set at 3k rpm it will blink if you're at 2500 rpm.
wonderizm
Sep 24, 2015 03:09 AM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
fredthesnail
Aug 27, 2015 09:26 AM
G35Sask
Engine - Intake/Fuel
Aug 1, 2015 11:16 AM
