Driver Seat Shift (problem)
Old Dec 10, 2003 | 12:25 PM
35Miami's Avatar
My 2003 G35 Sedan has a slight shift front and back in the drivers seat. The dealer tells me this is normal and there is nothing they can do about it. They state it is a factory problem with the gears in the seat and replacing the it wont help beacuse a new seat will have the same problem. Does anyone have this same problem with their electronic drivers seat? Did you get it fixed? Thanks.
Old Dec 10, 2003 | 01:01 PM
al503's Avatar
Re: Driver Seat Shift (problem)
They could replace the rails but it will only be a temporary fix. I don't think Infiniti has a permanent fix for this even though they've know about it for close to a year and a half.
Old Dec 10, 2003 | 01:12 PM
cato's Avatar
SouthernComfort Moderator
I have noticed the same. And I don't feel it all the time.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Dec 10, 2003 | 03:10 PM
OldPhart's Avatar
Have them replace the entire seat-lifter assembly (that is what they call it). I had the same problem and that was the only thing that worked. Don't listem to that BS that there is nothing that they can do. It is a saftey issue.
Old Dec 10, 2003 | 03:28 PM
SixFive's Avatar
They replaced my chair rails..dont take no for an answer. Even if it fixes it for a year or so - they can do it 4 more times IMO.
Old Dec 10, 2003 | 04:25 PM
BobP's Avatar
How bad is it? Mine does it on occasion, but it is barely noticable. I have not deemed it important enough to have anyone mess around on and spend multiple service visits for a condition that maybe I notice once a week.
Old Dec 10, 2003 | 05:36 PM
ABQ_G35's Avatar
Same here, I get an occaisional "clunk" but not annoying, and I don't really feel anything, I agree with you, not worth messing with at this point anyway!
Brilliant Silver/Graphite '04 Sedan/5AT
Old Dec 10, 2003 | 05:41 PM
OldPhart's Avatar
From what I was told, the seat movement seems to occur mainly when the seat is in the extreme up and/or rear position.
If you move the seat down and/or up and the problem goes away, it's the seat-lifter. The service dept inadvertantly left the bad one in my trunk and I was able to take a look at it. There was a bushing that had become elongated. Perhaps the new ones are made from a different material. I know, I should have taken a picture of it before I returned it to the dealer.
Old Dec 10, 2003 | 05:44 PM
OldPhart's Avatar
My goof....I ment to say if you move the seat down and/or FORWARD....sorry
Old Dec 10, 2003 | 09:08 PM
ryoken's Avatar
How bad varies. Mine was rather bad.. quite a bit of play, and everytime you hit the breaks more than lightly, you felt like you were being thrown forward an inch or so. Disconcerting every time it happened. Replacing the seat-lifter assembly fixed it. I just had it done a month ago, so no results yet on how permanent/temporary this is for me.
Old Dec 10, 2003 | 09:14 PM
ABQ_G35's Avatar
Now that would be grounds for taking it in! Hmmm, I hadn't noticed the seat lifter, I will check that and see if the clunk happens again!
Old Dec 11, 2003 | 01:38 AM
socalg35's Avatar
It will occur again, took mine about 3 months.
'03.5 BS Sedan, tint, XM, GroundingGear, Premium, Willow, Zaino, etc.......
Old Dec 11, 2003 | 09:36 AM
cmpterman2's Avatar
I just had mine replaced (seat lifter assembly) on friday. So far so good. Hopefully it won't come back.
Old Dec 11, 2003 | 01:48 PM
ncozby's Avatar
Mine has a very slight clicking noise and a barely noticable rocking. I'll probably ask them to fix it at my next service.
<font color=blue>03 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon w/Silverstar Fogs
30% Tint - Clear Corners - 5-Wire Grounding Kit
MB Quart / Eclipse Stereo
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Dec 11, 2003 | 04:26 PM
grmensz's Avatar
Yep, Infiniti hasn't got this figured out yet. They first installed whatever part gets replaced as part of the TSB, checked the seat and decided that hadn't fixed it. So, they replaced the whole frame. That was about 5 months ago.
Guess what I'm doing on Friday? Taking it back in because the problem is back. We'll see what they do this time. Haven't tried fooling with height adjustments as some have suggested. I need to have the back portion of the seat all the way down (tall upper body) or I get too close to the ceiling, so have no options with height adjustment. Passenger seat is solid as a rock.
Gary...
slider_ua
Jul 29, 2015 04:17 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
