Rear of the car uneven
Old Mar 20, 2007 | 11:11 PM
sliderg35's Avatar
Did I mention that I had Tein Flex Coilovers? I had them adjusted perfectly level when I installed them and I have adjusted them a couple of times since. So, when I say that they don't level out after a turn, it's because I have done the experiments to verify it!
Old Mar 21, 2007 | 02:48 AM
Crespo's Avatar
my car was like that when it was new too...I found out two weeks after I got the car. I just brought it back to the dealership and they got me a new set of suspension.
Old Mar 21, 2007 | 08:26 AM
bert039's Avatar
What about the amount of gas in the gas tank? Is the gas tank on the passenger side?
Old Mar 21, 2007 | 01:44 PM
sliderg35's Avatar
The tank is plit in two sections, pretty even center of mass.
Old Mar 21, 2007 | 02:22 PM
OCG35's Avatar
plus, it's not always the passenger side that’s lower... Mine is driver side - even with brand new springs (so it's not my weight)... I think it's just the structural tolerances of the car... some might be spot on, some might be fractions of an inch off...
Old Apr 18, 2007 | 02:36 AM
(>")> G35's Avatar
Figured out why one side was lower than the other side a couple of days ago. I was playing with my LED flashlight and decided to take a look at the rear suspension components. I could see that on the left side, the rubber spring mount was nearly flush with the socket it goes into, however on the right, the spring mount about about 1/4" sticking out from being flush....my guess since it's rubber, they'll settle differently and over time it get lower too...
Old Apr 18, 2007 | 09:34 AM
chinaman_87's Avatar
I should look into this cause my driverside is leaning as well, thanks for the suggestion
Old Apr 18, 2007 | 03:31 PM
gwhiz35's Avatar
Did you have the gas filler tube recall done on your car? IIRC that entails removing part of the suspension on the right side. Maybe they didn't put it back together right.
Old May 3, 2007 | 05:35 PM
Gspott's Avatar
My G as well, didn't notice it with stock springs, but once I installed my Eibachs.... sure did notice it. 5/16" difference. Drivers side is lower. Took it back to Stillen & they said that some G's come from the factory like that. Can't do anything about it. Like some one said, as owners we want things perfect & we notice everything as myself. Hardly noticable to anyone else.
Old May 3, 2007 | 05:42 PM
Kris79's Avatar
battle froggy
wierd the last couple days i been messing with my teins cause of this issue and i go on the wrong forum by accident and see this thread.i was wondering why with all the coils set the same my rear pass side is higher. cool now i know its nothing wrong with my coiloers
aww i miss my sedan.
rezendvous420
May 31, 2020 01:26 PM
TWASkyliner
Feb 8, 2020 08:00 PM
Soumilg
Jul 18, 2015 12:33 PM
