Rear of the car uneven
I just noticed that my car isn't that even in the rear. The rear driver side is actually about 1/4" or so lower than the rear passenger side. Also the driver side wheel is a little more tuck than the passenger side. My car has about 3.7K miles on it and recently I had my wheels changed. So what gives?
Yup, I still have the stock sport suspension. I guess i need to bring it into a shop to have it looked at or should I have the dealer take a look first? Does anyone know if they have to take off your wheels for an alignment?
Originally Posted by (>")> G35
Should I just take it to dealer first? I bought my car brand new and no one else has driven it but me....
Mine had the same problem but it was 3/4 inch out... The dealer put it up on the lift and couldn't find anything wrong. When he put it back down everything was fine. It could just be where you went before you stopped. The springs are pretty stiff and they don't settle out flat after cornering.
It is very common... not necessarily correct, but common. Unfortunately, there isn't really anything you can do. It’s not as noticeable with OEM springs since the gap is bigger… it becomes more noticeable when you lower – then ¼” seems very distinctive. Some cars seem to be worse than others… no one ever notices as much as the owner (I’m the same way).
