Some Questions
Old Mar 25, 2007 | 04:26 AM
yuanchen's Avatar
Question Some Questions
If i want to fit 05/06 hu to my 03 what will i need other then hu ?
My car under the dash has some rattling noise when i going throgh bumps, when only at 25 mph or less. Can some help me with this ?
Thanks
Old Mar 25, 2007 | 02:28 PM
5150DS's Avatar
Just do a double din.
Old Mar 25, 2007 | 04:36 PM
G35 Mass's Avatar
Why change head units?
there are probably 1500 individual parts that make up the dash. No, we can't help you with that question.
Old Mar 25, 2007 | 07:04 PM
OCG35's Avatar
Thanks
Is it a rattle or vibration/buzz?... If it's a buzz it could be plastic on plastic center console pieces butting up against each other. Mine buzzed on the passenger side. A very thin piece of foam spongy tape takes care of it. But like G35 Mass said there are about a billion things it could be. However there are reports of multiple similar rattles, buzzes, creaks, etc so I thought Id throw the one I have that sounds most like what you are describing.
see attachment for location.
File Type: doc
Old Mar 25, 2007 | 07:28 PM
BadBoy06's Avatar
best to have someone drive while you listen underneath dash
at least this way you can have a better idea where sounds are
coming from
Old Mar 25, 2007 | 11:31 PM
yuanchen's Avatar
I am pretty sure the rattling is caming form under the dash and when it rattles i can feel on my brake. And thanks guys for the help
Old Mar 26, 2007 | 01:42 PM
ttrank's Avatar
Grocery getter
You feel the vibration causing the rattle in your brake.
Old Mar 26, 2007 | 10:21 PM
yuanchen's Avatar
Yes i suspect it is something is losing i think, but i dont know if i am right or wrong
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
