Bad Door Seals?
Old Dec 16, 2003 | 05:45 PM
g35john's Avatar
Re: Bad Door Seals?
Oh and I forgot to say, thanks to all of you that have replied. I really apreciate it
Old Dec 17, 2003 | 07:35 AM
cato's Avatar
SouthernComfort Moderator
Re: Bad Door Seals?
g35john,
I have had all my doors off to fix rattles. The rear doors are different
from the front ones in thar the rears have a removeable wheather
seal. I had to partially remove them to access the speaker wires.
Is it possible that they were not or are not properly set? There
should be much less air coming in from the rear doors than the
front, IMHO.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Dec 17, 2003 | 12:29 PM
g35john's Avatar
Re: Bad Door Seals?
Thanks for the info. Ill be taking them off today. Do any of you know weather or not theG 35 has that plastic sheet that is glued on between the door and the panel? I just want to make sure all of my stuff is there that is supposed to be.
jbmw002
Sep 3, 2015 08:42 PM
UT G35
Sep 3, 2015 03:58 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
will091195
Jul 27, 2015 09:19 PM
newg37
Jul 26, 2015 09:32 AM
