Vibrating Over 80mph
Old Apr 11, 2007 | 09:45 PM
killerlexus's Avatar
my front passenger wheel seems like it vibrates when i go over 80mph. but nothing under 80mph. the vibration is still felt going over 100mph. had my front wheels balanced and alignment on car. but still vibrates on the highway
Old Apr 11, 2007 | 09:48 PM
Chrlesmd's Avatar
Get the balancing checked again, one of the weights could have fallen off. Or, could be a rotor problem. Just get someone to look at it. Wonder if the teins have anything to do with it.
Old Apr 11, 2007 | 10:10 PM
i just swapped out pads and rotors.. still vibrating. could it be a frozen caliper? or something in the driveline? dam this sux..
why you say the tein spring have something to do with the vibrating. its not constant, just over 80.
Old Apr 11, 2007 | 10:14 PM
Nismo G's Avatar
How the hell did you get vinrating out of vibrating?
-Sean
absolutg's Avatar
workin...
n and b are next to each other on the keyboard
Old Apr 11, 2007 | 10:16 PM
Nismo G's Avatar
HAHAHA, didnt even think of that.
-sean
Old Apr 11, 2007 | 10:46 PM
nghiars's Avatar
check your brakes... rotors pads
Old Apr 11, 2007 | 10:49 PM
maj83's Avatar
lazy a$$
have you checked the spring?
Old Apr 11, 2007 | 11:23 PM
OCG35's Avatar
-Sean
What you never got your VIN Rated?... It's a must!
Old Apr 12, 2007 | 09:50 AM
why would springs cause vibrating.
are teins known for that?
had teins on a lexus and it vibrated too after 80mph. the car got totalled before i could figure out the problem.
thanx
Old Apr 12, 2007 | 12:33 PM
Xer's Avatar
Xer
I seem to get a high speed vibration from the passenger side front wheel, I also getthis at normal speeds every morning, until the tires warm, then it seems to be minimized until I get up to higher speeds... 06 g35x
Old Apr 12, 2007 | 01:29 PM
jimmyc13's Avatar
Well what are you doing driving 80 MPH anyways!? How bout don't speed & you won't have any issues! Kidding....
Old Apr 12, 2007 | 01:50 PM
kvangil's Avatar
high speed vibration is usually an issue with rims/tires. Out-of-round, out of balance, uneven wear, etc...i'm going to say it may need to be balanced again. Do you have stock rims/tires, or aftermarket? I've had issues with certain aftermarket RIMS in the past where the tire shops could just never get them balanced properly....Even after 5 visits...
Old Apr 12, 2007 | 05:41 PM
i am riding on stock rims. going to rotate the rims tomarrow to see if the vibration goes away.
any one else want to chime in?
Old Apr 12, 2007 | 07:14 PM
aszatk01's Avatar
funny...i have the SAME problem (coupe)
at over 80 also.
i'm hoping its an alignment i will get done soon.
please let us know how it goes....
