2004 g35x flat tire indicator
Originally Posted by RAYNYC
wont go off after i changed the flat? anyone know how to reset it?
thanks
ray
thanks
ray
Did you replace the flat with the full-size spare? If so, you do have to go to the dealer to get the monitoring system reset to recognize the new sensor in the spare. If you got the flat fixed and put the same tire back on, its possible that the TPMS may be OK, but it still might be a good idea to have the dealer check it out. Its easy enough for them to do. They simply plug in one of their CONSULT II units. If the TPMS is not OK they have a second small unit they use to go around and force the sensors in the wheel to register.
I just had mine done at Ray Catena in Bridgewater, NJ after I had new tires installed on a different mix of wheels. First thing they checked showed that the TPMS had disabled itself because it was confused presumably over the new combination of pressure sensors. The warning light came on twice before I got to the dealer then shut off and never came back on. So I assumed that it was OK but it had disabled itself. Took all of 10 minutes for them to reset everything and didn't cost a dime.
Srinidhi
Aug 7, 2015 03:38 PM
