drag coefficient
Old Feb 3, 2003 | 07:26 PM
BMR1717's Avatar
drag coefficient
I understand that the G35 sedan has a very low drag coefficient with the aero package. Is a lower drag coefficient always better? I mean the drag coeff. is 0.26 with aero package and the Ferrari enzo's is 0.34. Is lower always better is my question...
Old Feb 3, 2003 | 07:32 PM
stewa101's Avatar
Re: drag coefficient
Well, lift also poses an issue. The enzo gets negative lift (downforce) at a certain speed. The fact that it doesn't cut through the air as well doesn't mean that it isn't holding the road better and getting more force where it needs to go.
Andrew
2003 coupe 6MT blue premium aero (on order)
Old Feb 3, 2003 | 07:43 PM
Dan_1's Avatar
It just means the air flows around the body of the G35 better then the Ferrari....
Lower Drag Coefficeint is always better... less wind resistence... has nothing to do with down force, which I beleive your thinking about....
Being the Ferrari needs more downforce because of its fast acceleration and top speed, they probably had to sacrifice Drag Coefficient in order to acheive the down force... but since our cars wont go near 200 mph, we dont need the down force and thus its easier to obtain a lower drag coefficient..
Old Feb 3, 2003 | 08:00 PM
stewa101's Avatar
Correct, downforce has nothing to do with the coefficent, I was just using that as an explanation for the ferrari's higher coeffecient.
Andrew
Old Feb 3, 2003 | 11:05 PM
Gordgee's Avatar
Administrator
Down force is important at high speeds. Cd means very little when you've got 650 HP to push through the air.
Old Feb 3, 2003 | 11:15 PM
ryoken's Avatar
Not true. If you're talking about achieving high speeds, lowering the Cd helps more than raising the HP. 650hp can push an aerodynamically slim vehicle much faster than it can push a brick.
Old Feb 6, 2003 | 11:49 AM
stewa101's Avatar
you're not talking about a brick, you're talking about a ferrari with a still awesome .35 Cod. It needs the downforce more than the couple hundreths off the Coefficient.
Andrew
Old Feb 6, 2003 | 12:26 PM
Gordgee's Avatar
Administrator
Agreed. All the gizmos (wings, spoilers, etc) add to the Cd and are important to the Ferrari even being able to get up to and be driveable at high speed. It's a balancing act and a science. 0.35 Cd is still relatively slippery and the 650 Hp gets you up to speed.
Old Feb 6, 2003 | 02:25 PM
KongzGx's Avatar
does the Cd relate strictly to the configurations of this car stock? would there be any difference in drag on a turbo or SC'd G?
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Feb 6, 2003 | 02:28 PM
stewa101's Avatar
CD has to do with air touching the outside of the car. A supercharger or turbo wouldn't affect the Cd unless the car had modifications done to the exterior.
Andrew
Old Feb 6, 2003 | 02:33 PM
KongzGx's Avatar
i didn't mean the mere addition of these components, but does the drag change at various speeds and acceleration?
Old Feb 6, 2003 | 02:36 PM
stewa101's Avatar
Drag does, but the coefficient of drag is a constant.
Andrew
