What can I do to improve handling on an 05X?
Old Apr 26, 2007 | 01:04 PM
Iwantagsedan's Avatar
Where do you get this info from????
Originally Posted by aam6906
nope x always has smaller brakes
All research that I've done says that all G35 sedans 05-06 received 12.6" front rotors.
check out
www.nissannews.com
Old Apr 26, 2007 | 01:41 PM
Konsole's Avatar
The 05 has smaller brakes. The 06 got the dual piston (per wheel) larger 12" brakes.
Old Apr 26, 2007 | 01:56 PM
Is anyone reading before they post???
What information can you provide to back this up???
www.nissannews.com says otherwise
Old Apr 26, 2007 | 02:33 PM
ma_sha1's Avatar
This has been debated a year ago, check this thread:
https://g35driver.com/forums/showthr...highlight=g35x
Unfortunately, what he stated is true. The G35x 05 is using the smaller
brake/rotor from 04 sedan. The 05 non X sedan received a upgrade.
You can't always trust "news". Read your owner doc & look up the specs.
I believe 06x finally received brake upgrade, but I am not sure. What I am, sure is that 05x has smaller brakes than 05 non X sedan. I know that because I upgraded my 05 X to wilwood BBK.
A quote from Gee35x prior post:
For your info I looked at my 04 brochure and for the sedan it shows;
Front 11.7 x 0.9 inch ventilated discs.
Rear 11.5 x 0.6 inch ventilated discs.
For the 05 Sedan G35X;
Front 11.7 inch ventilated disc
Rear 11.3 inch ventilated disc.
So the 05 and 04 G35X fronts are the same diameter
__________________________________________________ ___
Old Apr 26, 2007 | 03:07 PM
Sorry I'm new to the community....
that sucks!!! my girlfriend has the car right now, when she gets back I'm going to do some snooping around in my front wheels.
Old Apr 27, 2007 | 05:29 AM
poorman's Avatar
It's true my 06 G35X come with 12.6" brake in the front. Just put in new rims last month and measured it.
Old Apr 27, 2007 | 05:36 AM
poorman's Avatar
I have Richi fsb, Eibach rear adj. sway, and 04 Maxima SE rims&tires 245x45x18. The rear sway and bigger tires really help the car conrer better. As for the fsb I only feel like I can steer the car faster that's all.
Old Apr 27, 2007 | 08:35 AM
KrazyEd's Avatar
Yeah, the 05x has the same brakes as the 03-04s. So if you are looking for a BBK, you can get one that fits those years.
Old Apr 27, 2007 | 10:24 PM
j-champaco's Avatar
how many people REALLY make use of their 1k+ suspension?
i say lower it a tad and you'll be fine!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NailBomb
Oct 28, 2015 07:53 AM
