What Mod to do Next?
Old May 6, 2007 | 08:37 PM
Andy2434's Avatar
Originally Posted by jimmykce1
Why A spacer?? According to Motordyne the MREV2 would give you more gains thaan the spacer. Explain why the spacer instead of the MREV2, please.
Your sig suggest that you own a '06 Twilight Blue G35 Sedan 5AT. The 5AT has a non RevUp engine. The MREV2 was designed for the RevUp engine. G's which have the RevUp engine are ones which were made from '05 through '07 and came equipped with a 6MT.
Here is the link to the Motordyne site:
http://www.motordyneengineering.com/G35.asp
Old May 7, 2007 | 01:42 AM
ttrank's Avatar
Grocery getter
Would love to have twin turbos put on, but I think I need other mods first like exhaust, sways, and intake. However, my bank account right now doesn't allow my to drop 8k on twin turbos.
Yeah I know, just had to be a pain.
The sways and spacer will be your best bet.
Old Jul 13, 2008 | 03:31 AM
G35MTK's Avatar
Sorry to revive an older thread, but I thought this was a useful bit of information for those with non-REVUP looking into the MREV 2.
From MotorDyne's website at the very bottom:
MREV 2 Manifold:
The Motordyne MREV 2 Manifold is high-torque plenum mod designed for use on any VQ engine.
When used with a 5/16" spacer on the REVUP engine, every test to date shows MREV 2 Manifold will add a "minimum" of 15+ HP and 18+ TQ at 4500 RPM. MREV 2 Manifold is easily the single most effective bolt on modification available for the REVUP VQ engine.
When used with on the non-REVUP engine, the gains are very similar to that of the 5/16" spacer but the MREV 2 Manifold will show a slightly lower peak value, with a slightly higher average value and a slightly higher TQ value. Overall, MREV 2 Manifold provides "area under the curve" and is the highest gain plenum mod available.
Also, not sure on the details but MotorDyne's site says:
Note: A $100 core exchange rebate is available for those of you with non-REVUP lower collectors. Contact us for more information.
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
