Side Marker Mod (flashing) for Sedan Update
Old Oct 8, 2010 | 12:02 AM
NMG-4's Avatar
lol!
Old Oct 8, 2010 | 12:12 AM
NMG-4's Avatar
thank you .to me looks pretty simple.
Old Oct 8, 2010 | 02:49 AM
thescreensavers's Avatar
Mr.202?
I forgot to ask, will both the blinker and sidemarker work at the same time? I have seen them operate different times in other vids.
Dont know if I should do this since I have a white LED in my corners
Old Oct 8, 2010 | 09:42 AM
G35Papa's Avatar
With the lights off, the blinker and side marker will fire at the same time. With the lights on they will fire opposite each other.
Look at the link I posted, there are 2 vids at the top of the page.
Old Oct 8, 2010 | 12:47 PM
WILLIE BEANS's Avatar
the bulbs in there are stock right .?
wonder if i need to do anything else to be
able to use l.e.d's as blinkers in the sidemarker
Old Oct 8, 2010 | 01:13 PM
CG4DR's Avatar
Buy a 194 led
Old Oct 8, 2010 | 01:27 PM
yeah storm i have leds already .
i was just wondering if the leds will hyperblink .
instead of just blinking normally.
Old Oct 8, 2010 | 02:04 PM
OKStateG35's Avatar
I would think they would hyperblink unless you install a resistor. Maybe it's different since it's tapped into the turn signal though. Since it's so easy, you could always just try it and see.
I think I'll do this mod tomorrow when I have the car up on jack stands for some 60K maintenance.
Old Oct 8, 2010 | 02:08 PM
thanks and yeah thats what i was thinking of, but couldnt remeber what it was called i might need .. a resistor ..
k well post pics / vids .
thnx .
Old Oct 8, 2010 | 02:27 PM
NMG-4's Avatar
you can use this http://www.v-leds.com/BlinkerWarning...83296-1-3.html
Old Oct 8, 2010 | 05:55 PM
NFSP G35's Avatar
? = 2B || !2B
Maybe I'll just modify a set of clear corners with LEDs. Have one row that's the marker, and another row to blink sequentially with the indicator
Old Oct 8, 2010 | 08:57 PM
CG4DR's Avatar
do you have just regular diodes or are they the surface mount? the surface mount might not hyperblink.
CG4DR's Avatar
Originally Posted by G35papa
With the lights off, the blinker and side marker will fire at the same time. With the lights off they will fire opposite each other.
off and then off again. got it
do you not do anything with the black wire that goes up to the main harness? don't tie it into anything?
Old Oct 8, 2010 | 10:13 PM
G35Papa's Avatar
^ooops....second OFF should be ON
No, just cap the loose wire
Old Oct 8, 2010 | 10:44 PM
  #30
CG4DR's Avatar
were they the same colors chris?
