disconnecting battery
Old May 16, 2007 | 08:32 PM
IP05G35's Avatar
My wife forgot to put on the gas cap so the service engine light is on. I'm havign problems disconnecting the negative battery terminal... the bolt is a 10mm but it doesn't seem to move at all with my socket wrench... how long before the check engine light goes off by itself, also any tips on getting the bolt off?
Old May 16, 2007 | 08:44 PM
chinaman_87's Avatar
took like a day or two I forgot. I'd just let it go off by itself
Old May 17, 2007 | 01:51 PM
ttrank's Avatar
Grocery getter
You can always take it over to any parts store and have them clear the code.
Old May 17, 2007 | 04:05 PM
jameyb's Avatar
Try using a wrench. The socket you are using might not be deep emough (that's the only reason I can think of for your problem).
Old May 17, 2007 | 04:09 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
+1... use the box end of a 10mm combination wrench.
-GP-
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
happydays888888
Oct 6, 2015 06:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
