J Matic replacement ATF
Old May 18, 2007 | 09:06 PM
HypnoticG35's Avatar
IMHO, I would never use an alternative transmission fluid, automatic or manual, unless it was a direct replacement or it supercedes the OEM fluid specifically. Some companies use additives or detergents in their fluids. Those of which could be harmful to the seals/parts in the transmission unless they were designed to use it.
Another thing to is that not every transmissions have the same tolerances. Some people may think that having a higher viscosity fluid would be better because it's thicker and would stick better to the parts that needs to be lubricated. However, if the transmission has tight tolerances, thicker oil will not be able to work it's way into those areas. It also works vice versa, if the viscosity is lower, it may not lubricate it enough.
Old May 27, 2009 | 06:25 PM
bythabay's Avatar
I've been using the Amsoil ATF for several Gs lately and it has been performing very well.
Old May 27, 2009 | 07:05 PM
TheTick's Avatar
I just did a drain and fill with S matic. If you drop the rear of the car down, you can get 4qts out.
Old May 27, 2009 | 08:45 PM
pwebb's Avatar
S replaces J. using S would be perfectly fine.
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
miata007
Aug 17, 2015 04:36 PM
newg37
Jul 26, 2015 09:32 AM
