checking manual transmission fluid
Old May 24, 2007 | 06:14 PM
captainL's Avatar
Question checking manual transmission fluid
So...I have a 2005 6M. I am doing the 18,750 mile checks. .how do you guys check the manual transmission fluid level. For maintanence purposes do you just check for leaks or do you actually check the level? I am assuming you check the fluid level at the filler plug. Is it necessary to replace the gasket on this one and what kind/size of gasket does it use? Is there any other way like on the Automatics? Also does it matter if the car is warmed up or not? Thanks.
Old May 24, 2007 | 07:43 PM
g35rcr's Avatar
unless you see a leak you are fine...just change it at 30k miles
Old May 24, 2007 | 08:10 PM
obender66's Avatar
I agree, visual inspection for leaks is enough.
Old May 24, 2007 | 08:43 PM
captainL's Avatar
Makes sense. Thanks.
Old May 24, 2007 | 10:46 PM
ttrank's Avatar
Grocery getter
I change mine every 10-15k. Overkill I know but worth it.
Old May 25, 2007 | 06:53 AM
g35rcr's Avatar
not when you are forced induction
Old May 25, 2007 | 03:38 PM
ttrank's Avatar
Grocery getter
True.
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
multimut
Canada
Jul 26, 2015 08:43 PM
nervseele
Jul 17, 2015 11:21 PM
