Finally Put On 350z Suspension - 56k Warning
Old May 30, 2007 | 09:14 AM
Metalp3n's Avatar
Originally Posted by VQ Hotness
Wow your car looks pretty low for only putting on 350z suspension.. It just might be the combination of a pretty small tire wall and small rims b/c theirs no tuck that i can see... But none the less its looking good. Are you keeping thoses rims. If so i would invest in some Spacers. Keep it up.
Well getting aftermarket rims feels like it would be a waste here with all these potholes, so I've been thinking to throw on either the coupe 19's or the coupe 18's, since they'll definatly handle the road.
Since im not sure yet though I may just cop spacers for the meantime. What is the real benefit with them, or are they all simply for look ?
Old May 30, 2007 | 11:31 AM
04NismoV35's Avatar
Originally Posted by Metalp3n
Yea looking at it from the side more and more It makes me want to put some spacers on there.
I really want to find coupe 18's first for it. If i do find a good deal Id love to get the 19's, but tires are just sp expensive in that size. Brooklyn roads aren't nice at all, so getting aftermarket rims feels like a waste of money with all these potholes and "canyons".
Spacers supposedly will give you a bit more stability and slightly better handling, but that might be arguable. Plus you will have more space to clear BBK's, although you prob need to go at least 15mm. That's what I'm doing, I've got OEM Brembo's going on soon, but I need 15mm spacers so I can keep my stock wheels for winter use.
BTW, I've got coupe 18's I'd rather sell locally if you're interested. They need a little cleaning up tho.
Old May 30, 2007 | 01:02 PM
perry05G35's Avatar
Look for hubcentric spacers while you are at it they will cost a more than an ordinary spacer. Hubcentric means the spacer comes in the same center bore that your factory wheels have so that there is no chance of vibration when you drive over 60mph there's some on eBay.
Old May 30, 2007 | 01:23 PM
jimmyc13's Avatar
Nice work! Damn, I was wondering why your car looks so much lower than mine.....I think it's an optical illusion w/ you painting your black trim to match your car!
How much did this run you to get all 4 sides painted?
Old May 30, 2007 | 01:33 PM
Metalp3n's Avatar
Actually I got "lucky" and did it off my insurance check after an accident, so really I have no idea how much it would run up on its own.
Old May 30, 2007 | 04:56 PM
killerlexus's Avatar
$weet $hizz.. there isnt anything bad that can be said about this mod. you must love diving into turns now. alot of the body roll is eliminated with this upgrade. now the car drives more like a sports car then a sedan.
Old May 30, 2007 | 09:20 PM
VinNYCG's Avatar
G SQUAD
lookin good bro. I definitely the fully painted front bumper.
-Vin
Old May 31, 2007 | 12:15 PM
jimmyc13's Avatar
Damn, you are lucky.
Old May 31, 2007 | 04:29 PM
SdanMan's Avatar
Are these the revised z springs and shocks or the old ones? Does this mod require camber adjusters?
Old May 31, 2007 | 06:55 PM
perry05G35's Avatar
SdanMan his springs and shocks came from a 2003 350z so the springs are unrevised as far as camber adjustments some of us with the unrevised springs have had to get the front camber kit to correct the negative camber but it's really up to you if you want the camber kit or not some can live with the negative camber and find it cheaper to just keep rotating their tires from left to right and/or front to back to keep the tread wear even.
Old Jun 1, 2007 | 12:03 AM
DaveB's Avatar
The car does look really low for 350Z springs. Is he running a shorter tire. My Z/coupe springs setup (same drop) doesn't look as low. Maybe when I paint the lowers in a few weeks, the car will look lower.
Old Jun 1, 2007 | 08:19 AM
Metalp3n's Avatar
The painted lowers will give it a lower look, but also I am on a 45 sidewall profile, rather than a 55 sidewall profile on my Falken tires.
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
Jadenkid22
Jul 14, 2015 12:33 AM
