Temperature/AC Display
Old Jan 10, 2004 | 10:14 PM
ABQ_G35's Avatar
Lately, I have noticed sometimes when I first start my car, once it's already been running, the "outside" temp reading is a lot higher than it actually is, comes down once it runs for a bit, how does this read the outside temp, is this weird, or normal?
Brilliant Silver/Graphite '04 Sedan/5AT
Old Jan 10, 2004 | 10:20 PM
FzyLgic's Avatar
Re: Temperature/AC Display
Totally normal - the temp sensor is close enough to the engine, and all that heat warms the area around the sensor. So when you first start your car, the ambient temperature at the sensor is higher than the real temperature. Once you drive a few miles, that warmer air is disbursed and you get a much more accurate reading.
Old Jan 10, 2004 | 10:57 PM
ABQ_G35's Avatar
Hey, thank you, that is kind of what I thought, this is the first car I've had with a display like that!
Old Jan 11, 2004 | 01:38 AM
FzyLgic's Avatar
No problem. I was just so damn happy to have a question I could answer :-)
Old Jan 11, 2004 | 10:22 AM
ABQ_G35's Avatar
That's a good one![img]/w3timages/icons/laugh.gif[/img]
Old Jan 11, 2004 | 06:23 PM
grmensz's Avatar
I had the same problem on my sedan. There is a TSB on this. They relocate the outside sensor. Since the update, this problem has gone away.
Gary
Old Jan 11, 2004 | 09:06 PM
ABQ_G35's Avatar
Oh, thanks, I had planned on asking about it when I go in for my first oil change, guess I still will!
Old Jan 12, 2004 | 08:15 AM
dholly's Avatar
I saw -4F on my outside temp display last week, brrr.
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
Old Jan 12, 2004 | 12:55 PM
pestilence's Avatar
somtimes I have noticed my temp reading to be stuck at 75.. when its clearly hoter than 75..... I should check that TSB out..
Old Jan 13, 2004 | 08:15 AM
alderran's Avatar
Not lately ... try always mine is hotter than the outside temp in the summer time too.... Is this really a problem? I figured it was the heat from the engine ...
Just wondering why I should request the TSB
2003.5 5AT Sedan Black/Black Premium/Winter Packages
Old Jan 14, 2004 | 06:24 PM
Xattica's Avatar
Very cool???
In Puerto Rico: 112 F.
That's hot...
Old Jan 15, 2004 | 10:00 PM
FLAG35's Avatar
mine does the same thing for a few minutes until the car gets moving. it doesn't matter much to me now in the winter cause i'm not using the autocontrol. but in the summer if it shows up either a lot hotter or cooler than it really is it will affect the fan speed and a/c air temp and could either freeze you out or not cool down fast enough. i'll just wait and see what happens.
plus manual control is all i've ever had in the past and i've survived to this point just fine.
04 6MT sedan, black/willow
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
