She got frozen? and died
Old Jan 11, 2004 | 09:05 PM
Dabearz454's Avatar
Went to start my car - and all its doing is making a clicking sound... engine isnt even turning.. Do you think its the starter...or what- hope not that serious i know its not the bat?
Old Jan 12, 2004 | 05:43 AM
NicNoobie's Avatar
Re: She got frozen? and died
I'm no expert, but when the "clicking" happened to me in two previous cars, it was the battery. It wasn't that the battery was bad, it was just that my battery connectors needed to be cleaned a bit. I know you already said it wasn't the battery, but it may be worth your while to take some sandpaper to the connectors just to make sure.
- NICNoobie
2003.0 AT Brilliant Silver Sedan
Premium Package\Graphite Leather\Signaling Clear Corners\AEM Intake (w/ Bypass Valve)
"Why are you my English not being understanding?"
Old Jan 12, 2004 | 09:43 AM
rajanb's Avatar
My guess is that the battery is dead. Switch the headlights on and crack the engine - if the battery is dead, you will see the headlights dim perceptibly while it tries to crank.
Try a jumpstart before doing anything else.
G35S AT / Ivory Pearl and Black
Old Jan 12, 2004 | 10:51 AM
cato's Avatar
SouthernComfort Moderator
1 week after we bought our new 2000 Maxima, the same thing
happened to us. Turned out to be a dead battery on my "new" car.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Jan 12, 2004 | 11:37 AM
ryoken's Avatar
Call up the Infiniti roadside assistance number and have them come out to help you. They may try to jumpstart your car, and if that works, you'll want to take it to the dealer and have them test the battery & alternator. It's possible that your battery just needs to be recharged. It could also be bad or the alternator isn't making enough current to keep it charged or the start is going out (though I doubt that.. the clicking you heard was probably the starter motor failing to engage because there wasn't enough electrical current). If they can't jump it, they'll tow it to the dealer for you. Either way, you want it tested. If there's an electrical problem, you need to have them fix it, or it'll just keep dying.
If it's just the battery needing to be recharged, you may want to double-check all your interior lights to make sure nothing was left on.
Old Jan 12, 2004 | 11:49 AM
ABQ_G35's Avatar
Doesn't the Infiniti have the "battery saver" thing that shuts anything off after being left on for a certain amount of time? My last two Ford's did, you'd think Infiniti would have that too! There has to be something wrong with his car, being this new, I'm sure it's covered by warranty!
Brilliant Silver/Graphite '04 Sedan/5AT
Old Jan 12, 2004 | 12:53 PM
pestilence's Avatar
sounds like a bad battery.. try to jump start it.. if it starts.. check the battery/alternator at the dealer.
Old Jan 12, 2004 | 08:42 PM
Dabearz454's Avatar
In the end it ended up that the battery was not dead, it was just not holding the proper charge as far as voltage goes. Basically the juice that it was keeping wasnt enough to start the car... so i guess it ended up being the batt after all... thanks guys
Old Jan 12, 2004 | 08:54 PM
ABQ_G35's Avatar
Warranty covered it 100%, right?
Old Jan 15, 2004 | 12:53 PM
GLuvin's Avatar
If the battery is not charging completely, you may want to have your altenator checked. A bad one will cause your battery to die quicker.
03 - Black - Premium - Wood - Aero w/ Spoiler
Z Tube - Stillen AirBox
Old Jan 15, 2004 | 06:44 PM
Dabearz454's Avatar
Actually they would not cover it... because i have 2000watts of stereo madness, and alot of piaa lights hehe.... but no biggy just new 120 dollar high cap. battery
magnetism80
Feb 1, 2019 10:00 AM
Thebaws11
Nov 30, 2016 12:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
AT23
Sep 15, 2015 07:44 PM
n2fooz
Sep 4, 2015 07:46 PM
