Another Problem :/ not liking the G right now
Old Jun 22, 2007 | 05:11 PM
digital1986's Avatar
Originally Posted by jimmyc13
Well if yours is a direct result of speed, then definitely not the rear support. Maybe you have a rock in your tire!!!!!!
I dont think it is. It fits the descripton perfect to that link I posted
Old Jun 22, 2007 | 11:02 PM
dklau33's Avatar
Originally Posted by cato
That happened to me, only it was an interior nut that had come off the valve stem. There were two nuts on valve stem inside the tire, the outer one came loose and dropped into the wheel. As I drove slow, I heard this clicking that drove me crazy. At higher speeds, the nut was kept against the tire. Took it to the Stealership, and they cahrged me more than $100 to tell me the sound was coming from within the tire.
Same exact thing happened to me! It drove me crazy trying to figure it out. It took a slow leak in that tire to finally find the culprit. I thought it was the axle click problem at first and had the TSB done.
Old Jun 23, 2007 | 02:43 PM
vulcanraven1's Avatar
Its definitely the Axle , get them regreased i had the the exact same problem but 2 dealers wouldnt warranty because i have a modded suspension , it cost me 150.00 to get both sides done , It fixed the problem .
Old Jun 23, 2007 | 02:57 PM
NonAme's Avatar
had the same problem in my 05
complained and complained to the service dude and he got fed up so he changed my axel anyway to get me to shut up.
when i did my rare interior clean up, i found a dime under the driver sit, it was under the floor covering and banging against the metal floor frame.
it appeared that was the source of my metalic clicking.
moral of this story is, do an interior clean up, lots of things fall to the right on the driver sit.
Old Jun 23, 2007 | 03:05 PM
Jedunnigan's Avatar
Bahahahahah...all that work for a dime.
Old Jun 23, 2007 | 03:18 PM
nghiars's Avatar
its the TSB issue that posted the link too.. so many G's have had that issue and dealers resolved it
Old Jun 23, 2007 | 04:26 PM
GreenGoblin's Avatar
The goblin resurrection
its had to hear in the clip but seems like axle click the faster you go the more it clicks
chinee
Jun 10, 2024 07:48 PM
wonderizm
Sep 24, 2015 03:09 AM
atk08
Jul 30, 2015 03:12 PM
EasySausage
Jul 14, 2015 11:17 PM
