Auto Start
Old Feb 9, 2003 | 06:38 PM
GetGo's Avatar
Auto Start
I got the auto start from my dealer when I bought the car it is great. Anybody else get this installed?
2003 G35 Sedan Desert Platinum/Black Interior Premium/Sunroof/Winter pkg
Old Feb 9, 2003 | 11:04 PM
EdRedS's Avatar
Re: Auto Start
Is that the command start? The one where you use the key fob to start the car up? If you did then you should know that the security feature of requiring a key with the chip in it has been nullified. In order to start the car with an auto start they have to trick the computer into thinking that the microchip is always in there.
Red/Canadian
Old Feb 10, 2003 | 08:47 AM
KongzGx's Avatar
Re: Auto Start
i was wondering how that auto start function would work, esp. with the chip function in our cars..
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Feb 10, 2003 | 10:14 AM
EdRedS's Avatar
Re: Auto Start
The way they do it is to use an extra chip and plug it into the computer using some sort of converter. So any normal copy of the key can start the car now.
Red/Canadian
Old Feb 10, 2003 | 11:32 AM
KongzGx's Avatar
Re: Auto Start
makes it a little easier to steal our cars then.
Old Feb 10, 2003 | 11:44 AM
ryoken's Avatar
Re: Auto Start
Don't cars from other manufacturers that have this kind of feature direct from the factory require the coded key in the ignition before they let you move?
Old Feb 10, 2003 | 04:14 PM
IQ9's Avatar
IQ9
Re: Auto Start
This feature may also affect your insurance discounts for your Anti-Theft system. Watch out you can really lose a nice discount.
03.5 Sedan/B. Silver/Premium/Winter/Aero
69 Chevelle BB/4.11's
Old Feb 10, 2003 | 04:20 PM
EdRedS's Avatar
Re: Auto Start
I don't believe that it is a factory option or the dealers here in Canada would be all over it with our winters. It was probably a dealer installed option which would have to be done the way any after market starter does....as I discribed.
Red/Canadian
Old Feb 10, 2003 | 06:18 PM
Rumble's Avatar
Re: Auto Start
Feature is nice to have, but I wouldn't sacrifice my programmed key for this. I rather be cold than make it easier for people to steal my G.
It's still a G thang!!
Old Feb 10, 2003 | 07:08 PM
GetGo's Avatar
Re: Auto Start
Hold on fellows...
I have it and I love it...
Here's what the dealer told me.
First... I had to get it installed by the dealer or else the car warranty would not be valid.
Second... He told me they would hide akey with the chip in it some place in the car so it could start.
Third... If I start the car and someone breaks in to steal it they would have to step on the break to shift it into drive, when you step on the brake without the key in the ignition the car stalls...
Any other questions, it is awsome...
Old Feb 10, 2003 | 07:28 PM
EdRedS's Avatar
Re: Auto Start
Have you ever owned a car with command start before?? That happens with any car if there is no key in the ignition, regardless of whether it comes with a chip in the key as a security feature,....what I am pointing out is that any key, copied from yours, without the chip in it can start the car now. I suggest you try to start the car with the emergency card key that you got and see what happens. If it doesn't start you shouldn't have much to worry about....although I'm not sure if the key is specifically cut so it can only open the door regardless of the chip, like they used to do with old GM's having a separate key for door and ignition.
I think the only way to really test this is to get a copy of your primary key made and check if it starts the car.
Red/Canadian<P ID="edit"><FONT class="small"><EM>Edited by EdRedS on 02/10/03 04:32 PM.</EM></FONT></P>
Old Feb 10, 2003 | 08:04 PM
ryoken's Avatar
Re: Auto Start
The credit card emergency key will turn the ignition cylinder. It's not cut special, it's only missing the chip. The valet key has the chip, but is cut different to not work in the glove box.
chinee
Jun 10, 2024 07:48 PM
derres
Aug 28, 2015 03:27 PM
joedaddy1
Jul 28, 2015 02:58 PM
realtalk21
Jul 20, 2015 09:07 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
