airbag light is blinking, whats wrong?
Old Jul 21, 2007 | 01:19 AM
minh's Avatar
I took out the radio to install fm modulator and after I put all the plastic pieces together, the airbag light blinks, I remember pluging everything back together, but if I missed something what would it be?
Old Jul 21, 2007 | 01:31 AM
RichardxG35's Avatar
my friend have the same problem bring it to the dealer i bet is the airbag sensor malfunction.. all they gonna do is replace a new sensor.. they can replace it real fast within a day..
Old Jul 21, 2007 | 01:33 AM
an yes is under warranty..
Old Jul 21, 2007 | 01:59 AM
minh's Avatar
but it didn't do that before I took he dash and glove box apart though?
Old Jul 21, 2007 | 02:18 AM
speedraver's Avatar
wassupMyNinjas! (^_^)
Just take it to the dealer... they'll fix it for free cuz it's under warranty. I did mine a month ago.
Old Jul 21, 2007 | 02:55 AM
g35philong's Avatar
I had the same problem that OP just mentioned a couple of weeks ago. Didn't do anything that i could of think thats to cause the blinking, its very dangerous if your airbag system indicates a malfunction, this means that your airbag may not deploy in case of an accident, so just take it to the dealer asap! it could be a malfunction that they will have to cover under your warranty!
Old Jul 21, 2007 | 03:18 AM
(>")> G35's Avatar
It might be covered even if it's out of warranty. I know honda pretty much has a lifetime warranty on all safety related items. My friend had the seatbelt replaced on his 93 integra a year ago for free and our 2001 accord had it's seatbelt buckel replaced for free as well.
Old Jul 21, 2007 | 11:20 AM
clinthammer's Avatar
When you take it to the dealer and since it is under warranty make sure you are nice and find a nice tech to deal with. They will def ask you if you modified the interior (audio, wheel etc).
They will either reset the light for you (you can DIY also but not recommened first time around) or have to change out the sensor or spiral cable for the airbag.
I mentioned spiral cable cuz i had this issue as well and did not modify any of my interior (unless you call adding a Junction Produce teddy bear a mod ). anyways the spiral cable: https://g35driver.com/forums/g35-sedan-v35-2003-06/158405-sedan-srs-airbag-light-spiral-cable-damaged.html
Good luck!
Luisgalvan33
Jul 19, 2018 08:16 PM
deschutes606
Jul 18, 2018 09:34 PM
mtlruss
Dec 20, 2015 01:51 PM
sh0rtys463
Interior
Aug 27, 2015 09:06 PM
leli_11
Aug 10, 2015 08:25 PM
