G35 Part failures and other problems
Old Jul 30, 2007 | 09:26 AM
lexusk8's Avatar
Originally Posted by cato
How to set limit switch? Mine now goes all the way up, then down 1/3.
You need to remove the door panel from the problem window, and press and hold the limit switch (hidden inside a small hole readily visible once you take off the door panel) while pressing the down switch on the window (do not press the auto function). More details on the problem and solution can be found in the link below:
https://g35driver.com/forums/g35-sedan-v35-2003-06/84366-problem-window-going-up-down.html
Old Jul 30, 2007 | 10:27 AM
ActionAl's Avatar
https://g35driver.com/forums/showthread.php?t=84366
Here is the Infiniti Service Bulletin: http://www.infinitihelp.com/Ownershi.../ITB04-033.htm
Old Jul 30, 2007 | 05:13 PM
nr2134's Avatar
New long block @ 28K.
Old Jul 30, 2007 | 05:17 PM
04NismoV35's Avatar
Long block? What happened there?
Old Jul 31, 2007 | 01:02 AM
ActionAl's Avatar
For three years I had no problems other than needing brakes. Now, my third problem in two weeks...today when I tried to check the oil, I had trouble opening the hood. I was a short distance from the dealer, so I had them take a look at it. The drivers side hood hinge was frozen. They were unable to free it, so a new pair is on order. They had a hell of time getting it closed. I hope this is the end of problems for quite a while.
Old Jul 31, 2007 | 01:10 AM
srsly's Avatar
i bought extended warranty so hopefully im covered for a while any1 else buy this? i have an 04 and bought the warranty Dec06 with 12k miles im covered until 90k or 2012 what ever comes first lol
Old Jul 31, 2007 | 10:30 AM
chaindrive's Avatar
brakes and tires normal wear and tear items milage 28k
Old Jul 31, 2007 | 10:43 AM
04NismoV35's Avatar
What do they charge for the extended warranty? I've been considering getting one as well.
Old Aug 1, 2007 | 03:45 PM
srsly's Avatar
i paid 1600 for 6 years 80 thousand miles i think which will pay for its self the first few times i bring it in after my factory one is up ....if u plan on havin the car for even a year outta warranty i would recomend it ....i paid outta the *** when my maxima needed work after its warranty..
srsly's Avatar
lol the forum blanked out A$$
Old Aug 3, 2007 | 09:17 AM
ActionAl's Avatar
I just picked up my 2004 G35X from the dealer and the emissions warranty covered replacing the cat and sensors to the tune of $1400. Why would the cat fail at 76K miles?
Old Aug 3, 2007 | 11:10 AM
nr2134's Avatar
Oil consumption.
Old Aug 3, 2007 | 12:29 PM
cato's Avatar
SouthernComfort Moderator
$950 spark plug change.
Old Aug 3, 2007 | 01:17 PM
lexusk8's Avatar
Whoa, you've changed spark plugs already? Wow you must drive a lot..
Oh yeah, the price for the spark plug change is unbelievable. That's roughly the price of a set of new tires right there!
Old Aug 3, 2007 | 01:33 PM
  #30
cato's Avatar
Long story made short. My 2003 sedan has 96,000 miles on it. Last year when it turned 90,000, I had the spark plugs changed. Dealer called me and told me, oil has filled up all the spark plug tubes, the gaskets disappeared and you need new valve covers along with new spark plugs. Labor and cost of OEM valve covers came to $950ish. I had brought my own spark plugs with me.
