How to measure the engine Oil level
Old Mar 20, 2018 | 11:07 PM
Urbanengineer's Avatar
The fact that INFINITI made the transmission cold checkable too makes me a happy DIYer.
Old Mar 21, 2018 | 10:29 AM
FreshLikeAG's Avatar
I'd still check it warm after driving around to make sure the fluid gets in all the paths of the transmission parts like the torque converter.
Old Mar 21, 2018 | 08:18 PM
G35CO's Avatar
i didn't know you can check the transmission cold. How do you read the dipstick?
Old Mar 22, 2018 | 05:22 PM
Remove the 10mm bolt/nut And check it out! Pretty neat. I haven't done it lately I forget tbh.
Old Mar 22, 2018 | 09:38 PM
Hall Stevenson's Avatar
Originally Posted by LoSt180
​​​​​ The distance between the H and L is a little more than a quart. You're roughly a 1/2 qt low.
That doesn't seem right. The "H" and "L" basically mean "high" and "low". Oil level right in the middle means it's dead-on.
Old Mar 22, 2018 | 09:43 PM
It doesn't necessarily REQUIRE it but the hatches on the dipstick are pretty shallow and don't hold oil well, you need good light and a few wipes of the dipstick to get a good reading...
It's even worse with fresh, new oil that's really "clean". Well, this applies to most cars actually.... Trick I know is lay the dipstick on a paper towel (like lengthwise along the radiator) and then "pull" the dipstick horizontally either away from you or towards you. It should leave a "streak". Keep the dipstick lined up to use the markings on it for reference.
Old Mar 22, 2018 | 09:49 PM
One side of the dipstick has hashmarks - use those when the ATF is hot. The fluid level should be within the hash marks. When it's cold, you use the two small notches or cut-outs for checking the oil level. It's best to flip the dipstick over so that the hashmarks aren't in the way as they do overlap.
Thing is, what Nissan considers "cold" isn't really cold, let alone ambient temperature (in most places). I think the temperature range they use for cold is 90-120º F.
Old Mar 23, 2018 | 04:54 AM
LoSt180's Avatar
​​​​I don't think it's actually H/L. Just a set of hash marks on the dip stick. Top is full, bottom is outside the safety margins. Middle means it's low, but within operating range.
If you do your own oil changes, dumping in 5qts puts it right at the top of the hash marks.
Old Mar 23, 2018 | 05:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
That's odd^^
I buy the 5+ quart jugs (not sure how much the plus adds, think it's ~1/2 qt.) and they fill it right to the top of the hash marks. Been this way since I bought the G 9 years ago.
Old Mar 23, 2018 | 06:17 AM
LoSt180's Avatar
That's odd^^
How is that odd? We just said the same thing, lol
Old Mar 23, 2018 | 11:07 AM
G2B35AGN's Avatar
Note the two carets at the end of his comment. That points to second post above. One caret would point to your post.
Old Mar 23, 2018 | 10:16 PM
No.
Haha.
Lost knows this car way better than you do.
Old Mar 23, 2018 | 10:54 PM
​​​​I don't think it's actually H/L. Just a set of hash marks on the dip stick. Top is full, bottom is outside the safety margins. Middle means it's low, but within operating range. ​​​​
No.
Haha.
Only going by what Infiniti says....
Old Mar 23, 2018 | 11:55 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I think that's the '03-'04 dipstick, traditionally oil.level is ALWAYS filled to the top of the hashmark, the more volume in the crankcase the better, never fill to the middle of the hashmark.
Old Mar 24, 2018 | 01:48 AM
  #30
Blue Dream's Avatar
Well this just got confusing. All I was saying is that for some, 5 qts. refills the oil to the top of the dipstick and on our G it takes ~5.5 qts.
But I did learn what a caret is tonight so thanks fellas for the education. I had no idea that one indicated the post immediately above and 2 referred 2 posts above.
