Car veers to the right
Old Sep 12, 2007 | 11:21 AM
Fassster10's Avatar
i got sick and tired of balancing and doing alignments on my G, is just too damn expensive, you hit a simple speed bump at 15mph and poof alignment is out of whack, WTF...arent they paying these Infiniti engineers mad bucks to get this sorta crap right from the get go?????plus they dont even offer a recal or something another WTF...is this a problem for also 06/07 G's???
Old Sep 12, 2007 | 11:37 AM
PSD G35's Avatar
I have an 04 6MTC, before I put on my 20" Axis wheels, I did not notice any type of pulling to the right, but once I had my after market wheels installed, the pull was noticeable. Frustrated from this, I took the wheels back to the wheel shop, had him order me 2 brand new tires (Falken BTW) and the pull was still there. I put on my stock 18" wheels and the pull was there, just not as noticable.
Since getting my new wheels, I had 3 alignments done (Hunter alignment machine) and numerous balance on the wheels, and took it to the dealership...no solution yet.
Old Sep 12, 2007 | 06:45 PM
MrPutzy's Avatar
Ya, do you have to remove any plastic covers or the airbag to do this steering wheel fix? I would like to look into this.
Old Oct 14, 2007 | 09:41 AM
clinthammer's Avatar
Well I visited a reputed wheel shop today and all the techs there were very professional. As far as alignment, all the wheels/tires were fine with no leaks or abnormal tire wear. They even rotated the tires and had the alignment tweaked a bit but the car still pulls marginally to the right. The tech there, Sri, said that I should give the alignment report to Nissan/Infiniti as it is now some suspension adjustment that has to be addressed - something minor which one of their customer 350z encountered.
Let see how helpful Nissan is now esp since this is an aftermarket add-on!
edit: he mentioned the castor could be an issue as well which Nissan can take care off.
Old Oct 14, 2007 | 10:43 AM
btw - I did have this problem when I had my stock 17" wheels and the car is under warranty going in for service every 5k. However, the front right wheel had a small puncture (stock wheel) so that could have been the reason.
but with these 19" Michelin ps2's ive gotten then aligned twice, no abnormal tire wear, no bent rims, balancing is proper, tires rotated, no punctures and it still occurs. Although after todays re-alignment and rotate the front tires to the rear the drifting is less.
Am going in to the dealer tomorrow so will have a word with them.
Old Oct 14, 2007 | 02:33 PM
dahkyne's Avatar
Originally Posted by psedog
Dahkyne, how do you adjust the steering wheel linkage?
you have to pull off the airbag and the large nut holding the steering wheel to the column
once you've removed the nut, you can see the alignment marks on the metal frame of the steering wheel and the steering column shaft - they should be lined up straight, as any degree off-center will cause the steering wheel to be askew when driving straight
if the alignment shop verifies that toe in/out and camber/caster of the front suspension are within factory specs, and you're still finding that the car veers in one direction or another when the steering wheel appears straight, the shop didn't center the steering wheel.
the only way to correctly do this without touching the suspension is... to check whether or not the alignment marks on the steering column are in-line with each other
if this does not solve the problem, then it's time to take it to the dealer
before going there though, drive the car on a flat road at about 25-30 mph - make sure that it's driving straight, regardless of how the steering is positioned. if it tracks straight, it may just need the steering wheel aligned. if it doesn't track straight, drive to the dealer instead...
Old Oct 14, 2007 | 03:11 PM
well car is under warranty so I dare not touch the airbag... large nut... else ill be selling my nut to pay the dealer for work
Old Oct 14, 2007 | 03:34 PM
HUMBOLDT_G's Avatar
sorry to hear bout your prob. I have an '05 with 49,000 miles and I have not a single prob with pulling. Even after I have lowered it and I have yet to align it and it been one month since the drop. Hope you can figure it out. IMO tires can make a huge diffenece. Try a diff brand when it comes time.
Old Oct 14, 2007 | 03:36 PM
HUMBOLDT_G's Avatar
No car shold go OUT of alignment when you hit a bump. If you understand what it takes to align a car you will understand that it just doesn't happen. I know it sure feels like it but all your suspension components are aligned by threaded parts and unless there are wallowed out and jumping threads this can't happen.
Old Oct 15, 2007 | 07:55 AM
can someone look at this report:
Old Oct 15, 2007 | 08:00 AM
RBull's Avatar
Rated M
Originally Posted by clinthammer
I had this problem with my stock wheels but there was a small leak in the front right stock wheel tire. I fixed that leak and the problem was still there.
then I got my VS-XX and pressure is at 36psi for all 4 tires. I had them filled up to confirm the pressure amount and then drove the car this weekend and the car still veers to the right slightly and I have to keep my hand on the wheel.
I had a proper alignment done, camber/toe corrected and wheels balanced as well.
Since I had this issue with my old tires what could the problem be?
The problem is your "proper alignment" wasn't proper. Take it back and have it redone explaining the problem. You've paid once so it should be done for free. G/L
Old Oct 15, 2007 | 08:03 AM
RBull's Avatar
Rated M
Originally Posted by 68_GT
now I'm curious. My 03 G35 has done this from day one. I bought it used and it pulls so slightly to the right I never thought to worry that much about it thinking it was alingment. My girlfriends 04.5 G35x pulled to the right just like mine did, and she took it back to the dealer who replaced front end parts and couldn't get it right so the car has been at Infiniti for 3 weeks now and they say they don't know what the deal is !
what is the deal with this ??
There is a TSB on this. You should have taken the car back to have it realigned since it's not right and alignments are free for the first 12 months.
Your girlfriend isn't having a good experience which is a shame. She should take the car somewhere they know what they're doing.
Old Oct 15, 2007 | 08:04 AM
the report above is from the alignment yesterday. they said they cant do anything more to correct it ( i dont want to force them too) and these guys are reputed.
I have given the report to Infiniti dealer here today so lets see if they can point out any errors.
Old Oct 15, 2007 | 08:15 AM
RBull's Avatar
Rated M
I did. Questions or comments?
Old Oct 15, 2007 | 08:35 AM
  #30
dofu's Avatar
20 Year Member
Your alignment looks ok, not great. The toe is very even... remember that when you get in your car, the wheels will toe out, and camber out a bit too (on your side specifically). You do want the SAI to be as even as possible or your car can drift, but I don't think that's adjustable, so that shouldn't be the problem. My guess is it's the camber...
