How to tell if seats have heaters in them?
Old Sep 18, 2007 | 02:06 AM
psedog's Avatar
Back in SD**
No, I mean I'm waiting for Infiniti to offer cooling seats. Having black leather gets friggin' hot.
Old Sep 18, 2007 | 11:38 AM
DieselX's Avatar
Originally Posted by ttrank
Can you take a picture of the harness on the bottom of your seats? I'll get some shots of mine and we can compare.
Since I have my seat off, might as well take a pic of the whole bottom lol
This is the harness, I have two empty wire slots, are yours filled?
Old Sep 18, 2007 | 01:00 PM
jimmyc13's Avatar
Originally Posted by DieselX
Your post was really pointless, thanks for no help
+1 no kidding....
Old Sep 18, 2007 | 01:14 PM
ttrank's Avatar
Grocery getter
I don't think mine were filled either. Let me take a look tonight. I had to cut the harness off my sedan seats and use them on the coupe seats but all the wires are there so I can check that. I'll let you know.
Old Sep 18, 2007 | 05:29 PM
DieselX's Avatar
Thanks Tim. You still have your stock seats? I'd love to see the bottom of an 03 heated seat. I would able to spot an extra wire right away or the actual heaters maybe
Old Sep 20, 2007 | 06:10 PM
ttrank's Avatar
Grocery getter
The seat heaters are inside the seat somewhere, you can't see them from the bottom. Both sets of mine look like yours.
I took a couple pics but I only found a few cut wires on the bottom of mine so I need to go look again. Plus the flash was way too bright.
Old Sep 20, 2007 | 06:20 PM
ttrank's Avatar
Grocery getter
OK, I started typing that last post hours ago and looked around a little more.
From what I can find, all the power seats have heaters. I can't confirm 100% but it looks to be true. If you PM me your email I can send you seat section from the ESM.
The wire colors appear to be Grey w/blue stripe, and Light green w/black stripe. As long as the typical nissan color name scheme is used for GY/L and LG/B.
They would be in pins 3 and 8.
Pin layout is
|-1-|-2-|-3-|-------|-4-|-5-|
|-6-|-7-|-8-|-9-|10-|11-|12-|
FYI - The factory switch uses a 10A fuse.
Old Sep 21, 2007 | 01:45 PM
DieselX's Avatar
Sending you a PM right now...
Old Sep 21, 2007 | 03:47 PM
ttrank's Avatar
Grocery getter
Sent you the seat section via email. From what I can tell there are only the power seats and non-power seats. The power seats have the heaters in them. I could be wrong but I think you have them.
EM3RGY's Avatar
so does that mean that if I have power seats, all I need is to hook up the switch??? would this be an expensive mod? how much are the parts?
Old Sep 21, 2007 | 03:52 PM
ttrank's Avatar
Grocery getter
If your seats are not power, then no, you don't have the power seats. There are two kinds listed in the ESM, power and non-power. You can add them but I'm not sure if you have the right harness or you would need to add the power wires and fuses.
Old Sep 21, 2007 | 03:57 PM
ScubaSteve312's Avatar
so in short all power seats might just have heaters built into them??
Old Sep 21, 2007 | 03:58 PM
ttrank's Avatar
Grocery getter
They might. Check to see if you have the two wires I said above.
Old Sep 21, 2007 | 04:07 PM
well i know mine has heated seats because i have the switches but i'll go check for the wires anyways
Old Sep 21, 2007 | 04:12 PM
  #30
DieselX's Avatar
Pin layout is
I don't think I have those. Unless my colors are different.
