How to tell if seats have heaters in them?
Old Sep 21, 2007 | 04:24 PM
  #31
ScubaSteve312's Avatar
k just looked, looks exactly like this which was previously posted
Old Sep 21, 2007 | 05:37 PM
  #32
ttrank's Avatar
Grocery getter
Originally Posted by DieselX
I don't think I have those. Unless my colors are different.
What do you have in spots 3&8?
Old Sep 22, 2007 | 02:09 AM
  #33
DieselX's Avatar
Instead of me explaining the colors, take a look...
Old Sep 22, 2007 | 12:08 PM
  #34
ttrank's Avatar
Grocery getter
So you have red/black and blue/yellow in those spots. I'll have to check to see what I have on mine. It might not be until early next week but I'll try to do it this weekend.
Old Sep 22, 2007 | 01:53 PM
  #35
DieselX's Avatar
Thanks man, I'll be waiting
Old Sep 22, 2007 | 06:19 PM
  #36
ttrank's Avatar
Grocery getter
OK, so I'm not at home so the only ones I could look at were my 04' coupe seats. These are not the same as the sedan but should have the same wire colors.
I found a second 4 pin harness that has those two colors I listed above (grey/blue and green/black).
But, my stock sedan plug looks just like yours and I have a number of wires that were not reconnected to the sedan plug I cut off my sedan seats (the coupe seats swap for my car was not direct and required changes).
Here is what I would do if I were you. I would get a fuse holder or make one out of some wire and two female spade sockets. Using the factory harness you found, wire into the colors per the ESM. Use a 10A fuse to be safe. Wire them into the high temp side, if the fuse does not blow, wait a few minutes and see if they get warm. If that works you should be able to get the oem switches from the dealer or make up your own with two SPDT (with off center) switches.
I can look into this more for you later once I get back to my laptop with the ESM.
-Tim
Old Sep 23, 2007 | 12:15 AM
  #37
DieselX's Avatar
I have some 07 heat switches, and they plug right in. When I get my car back (impounded by cops) I will put my stock seat it and connect the heat switch, and just see if it works. The reasons I didn't do this before is I have to take the whole center console off to test it out.
Old Sep 23, 2007 | 12:34 AM
  #38
OSKIRE's Avatar
Originally Posted by psedog
It is standard for 05-06, but not the earlier or new models. I think it's funny that the 07 doesn't have the heated seats standard. I'm waiting for cooling seats
+1 for guam heat...
Old Sep 23, 2007 | 01:12 PM
  #39
ttrank's Avatar
Grocery getter
(impounded by cops)
More details...?
Old Sep 24, 2007 | 01:41 PM
  #40
DieselX's Avatar
Sent you a pm, Tim.
Old Oct 27, 2007 | 06:49 PM
  #41
InvincibleG's Avatar
So did this work? Its getting cold in kansas and it would be great if it did
Old Nov 10, 2007 | 11:27 AM
  #42
DieselX's Avatar
I haven't had my car in 2 months, long story. I should get it back by the end of the month and I'll do the testing. Don't worry I haven't forgotten this thread, I really want it to work!
Old Nov 11, 2007 | 02:21 PM
  #43
ttrank's Avatar
Grocery getter
You still don't have it back!?! I'm sorry, I hope you get it back soon.
Old Nov 11, 2007 | 04:22 PM
  #44
EM3RGY's Avatar
yeah, I would gladly buy switches and a new wiring harness to make this work.
Old Nov 12, 2007 | 08:31 AM
  #45
So what will be the steps? Can I test it without the switches or just buy some cheap ones from the Shack to use for testing?
