Need help identifying what OEM part I need for a 2006 G35
Old Oct 2, 2007 | 07:31 PM
miltoda's Avatar
Guys,
I need some help figuring what replacement part to order. I have 2006 g35 sedan (28,000 miles) and I noticed today that the black plastic guard that runs below the bumper is cracked on one side and hanging down. I'm not talking about the engine guard, it's fine. I must have pull too far in on a parking curb or something. What does infiniti call this part and is it easy enough to fix/replace with simple hand tools? Thanks in advance.
Old Oct 2, 2007 | 07:36 PM
QuadCam's Avatar
i belive that is part of the front bumper.
Beebo's Avatar
just take it off you dont need it and it would be a waste to fix it will just happen again
Old Oct 2, 2007 | 07:37 PM
Beebo's Avatar
your thinking of 03-04
express705's Avatar
+1
Old Oct 2, 2007 | 07:49 PM
miltoda's Avatar
So from what I can tell the 03-04 the part was part of the front bumber (expensive probably) and the later years 05-06 it is separate. I looked at it..there are some black hex bolts underneath the bumper but I have no clue how it's all put together.
Old Oct 2, 2007 | 07:53 PM
absolutg's Avatar
workin...
isn't that a lower diffuser? not suer tho
Old Oct 2, 2007 | 08:01 PM
JOKER's Avatar
CLUB MODERATOR
Sedan
1) Bumper cover G35
2) Bumper cover Clip
3) Mount bracket Mount bracket Right
4) Grommet Grommet Back
5) Bumper cover Cover
6) Front bracket
7) Energy absorber
8) Reinf beam
9) Stay Right
10) Lower grille Right
11) Finish panel G35
12) License bracket
13) License bracket Grommet
14) License bracket Screw
15) License bracket Nut
16) Outer Outer Back
17) Protector Inner
Coupe
1) Bumper cover
2) Clip #1
4) Screw Screw Back
5) Bumper cover Grommet
6) Absorber Right
7) Energy absorber
8) Reinf beam
9) Stay Right
10) License bracket
11) License bracket Cover
12) Tow hook
13) Spoiler
14) Spoiler Screw
Old Oct 2, 2007 | 08:24 PM
(>")> G35's Avatar
On the sedan its molded in the bumper. Looks like on the coupe (#13) it's removable.
Old Oct 2, 2007 | 08:37 PM
JOKER's Avatar
CLUB MODERATOR
^Spoiler.
I thought he was talking about that.
In this case just brake it off.
Old Oct 2, 2007 | 08:58 PM
maximumvette's Avatar
Mine broke and was hanging from the drivers side. I glued it back but since I can't control the wife (even though we had a fight over not parking too close to those things) it was again broken this morning. I'm worried cause i have a lease and am afraid they'll want for me to replace the bumper.
Old Oct 2, 2007 | 09:01 PM
miltoda's Avatar
I just went outside with a flashlight and did some investigation. The part is actually part of the bumper. And its not even attached all the way around when it's undamaged. Just tacked every couple of inches. I seem to have cracked the passenger side edge of it and about 3 of the tacks. I guess the only way to really fix is to somehow glue it back (probably wouldn't look or work right) or replace the entire bumper (man that's expensive) I guess I could go aftermarket if the modding bug hits me soon. Thanks for the input guys. I've been learning alot about this car since I got it 3 months ago.
Old Oct 2, 2007 | 09:11 PM
I say if your not in a lease,, just take it off.
Old Oct 2, 2007 | 09:17 PM
miltoda's Avatar
Thats probably what i'll do. I have some good glue in my tool box and the way it broke seems like there would be plenty of surface area for the glue to hold on to.. If that doesn't work right i'll score it with a razor blade and snap all of that black unpainted plastic underneath the bumper off.
Old Oct 2, 2007 | 09:33 PM
QuadCam's Avatar
no, I'm not. I have an '05 , and I have been under this car alot. Mine is a little loose and has cracked at a few places. I have already thought about what I want to do.......and I'm pretty sure it is part of the bumper.
