Which Brand Coolant to use
Old Oct 5, 2007 | 01:54 PM
jimmykce1's Avatar
I am going to be flushing my radiator and would like to know which brand coolant to use back in the radiator. I was looking at using Prestone extend life. Is this okay??
Old Oct 5, 2007 | 01:55 PM
flipa77's Avatar
I would use the nissan.
Old Oct 5, 2007 | 03:00 PM
sloppymax's Avatar
preferably one with a low silica level.
Old Oct 5, 2007 | 06:43 PM
GeeDM's Avatar
Stick to the OG Nissan coolant
Old Oct 5, 2007 | 11:39 PM
gtbigup01's Avatar
Getting the gallon from Nissan will set you back about $21 inc taxes. Not that bad to put the stuff the car came with back in.
Old Oct 6, 2007 | 08:38 AM
gtbigup01's Avatar
Isn't it funny how we all suggest that you stick with the original Nissan fluid. How come this feeling doesn't apply for other fluids ie XSMN fluid, differential fluid? I guess we are selective of which stock fluids we trust
Old Oct 6, 2007 | 11:52 AM
GreenGoblin's Avatar
The goblin resurrection
you will be fine with the prestone but if you ant you can use the oem coolant
Old Oct 6, 2007 | 10:33 PM
callawayc7's Avatar
I use prestone coolant and have no problem. I don't think it is required to use OEM coolant. The only fluid that is required (for warranty) to be OEM is the transmission fluid.
Old Oct 6, 2007 | 10:37 PM
coolb's Avatar
I have been using Motul for two years,great product. I can tell it works better than OEM coolant
Old Oct 7, 2007 | 12:46 AM
ballisticus's Avatar
The Prestone is fine to use. Just make sure you get ALL the old stuff out by doing a thorough flush (2-3 times) through the system with the heater on high (75 degrees) to flush the core. Then refill with distilled water to a 50-70% conc. of Prestone and you will be good for 60K miles.
Old Oct 11, 2007 | 03:30 PM
FamousG's Avatar
When I had an Acura, I used OEM Honda coolant religiously and was thinking of doing the same with the G by using OEM Nissan coolant.
But when I called up my local Infiniti dealer, they said they use Pennzoil coolant in all the cars they service even though they sell the OEM coolant which is twice as much.
Old Oct 11, 2007 | 04:30 PM
jack_burton's Avatar
guys it doesn't matter, it's coolant FFS. Water+a little additive that doesn't allow water to freeze. My buddy works at a nissan dealership and they use prestone on all their cars. The dealer will use the coolant from the company who gives them best deal, and they'll say to use that. It has nothing to do with the brand of coolant, all of them are pretty much the same. You'll be fine with any coolant brand. I've heard the best mix is 70% coolant, 30% water.
Old Oct 16, 2007 | 12:47 PM
bythabay's Avatar
I'm upgrading to the Amsoil coolant at 60k miles (that's when the initial cooling system service is due, or 4 years). The amsoil coolant must be mixed with distilled water and the color of the coolant is yellow.
The factory service manual specifies an initial cooling system service at 60k followed by servicing every 30k after. The oem nissan coolant sold at the dealer is only recommended for 30k (according to the parts guys I've spoken with), so I believe this coolant is a great alternative. It also provides a 7-year / 250k service life, is non-toxic, and contains a great additive package. However, I will just stick to 60k / 4 year flushes instead of the 7-year / 250k spec.
jpg of service manual page:
pdf of service manual page:
MA.pdf
https://www.amsoil.com/storefront/ant.aspx
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
twentyeggs
Sep 11, 2015 03:58 PM
