M45 wheels on car.. need spacers on front.. what the smallest for clearance ????
Just put a set of M45 sport 19's on 05 sedan and have rubbing.. i knew I would but what is the thinnest spacer to be used and where to get it?? any help would be greatly greatly appreciated
... AND where to buy.. what brands yada yada yada.. thanks Derick
What I remember VQ hotness said he would go 10mm if he did it again. That would bring the wheel to a 40 offset and they would still tuck. It all depends on you, and probably how low you were going might play a role too.
Why would these rub?? I have an 05X that i don't plan on dropping, and want to get a set of these. Will they run without a drop?? What kind of spaces do I need to get for the perfect offsets??
The offest for the m45 wheel are a 50+, so that put the wheel to much in and it get really close to the suspension. VQ Hotness ran a 5mm and it was good. Another guy ran a 10mm and they were close of being flush. Also they should run np without a drop.
i have a 20mm spacers for sale that i was going to do for the fronts. the only reason i didnt install because i didnt feel like removing the stock studs. i tried and failed.
https://g35driver.com/forums/archived-sales/183715-wts-20mm-ichiba-wheel-spacers.html
Originally Posted by ashish
anyone know if a 15mm would rub on the fender?
so 15 no, 20 no
You have a coupe, he has a sedan. Two different offsets. As for a 15, I am going to say maybe. That would bring it to a +35 and right now I am a +35 with 20x8.5 but I got some neg chamber going.
sorry i meant rubbing for the rears. I just got 10mm spacers put in for the front, but am wondering how tucked the rear will look without spacers. And if 15mm will rub the fenders in the rears.
ashish
sup man, did you talk to your friend about the wheel spacers installation, if he could do it, i'll take the spacers off the market and have him install it. let me know wassup
