wheels not sitting flush on my sedan on s tech help!
Old Oct 25, 2007 | 11:17 PM
Crespo's Avatar
I had talk about this from my last post about what I can do with my wheels because my left front wheels are tuck in more than the right. So I got the SPC camber Kit, the mechanics had put all my wheels in perfect spec! but the left front are still tuck in than the right. The mechanics said that it might be caused by my last accedient, which the body shop said that I didn't hit the wheel nor the suspension.
I am wondering if there is a problem with my upper arm or lower arm with my susupension parts. you guys know anything about it?
THNAK YOU
Old Oct 25, 2007 | 11:25 PM
savefatkids's Avatar
its most likely because of the accident. my friend has the same problem with his m3
Old Oct 25, 2007 | 11:55 PM
Crespo's Avatar
May I ask what happen to his M3 afterwards? Did he found out what was the problem?
Old Oct 26, 2007 | 02:05 AM
ttrank's Avatar
Grocery getter
Is it way off or just a tiny bit? One side on mine sits a little further out too but you have to measure to tell. I just know because that side rubs and the other doesn't.
Old Oct 26, 2007 | 02:17 AM
MightyG35's Avatar
^^^^+1 Mine too. My rear passanger sits out a tad bit more.
Old Oct 26, 2007 | 03:26 AM
Crespo's Avatar
The right side sit really flush to the fender, and the top left side of the tire is about 2.5cm to 3 cm inward like this /
is it normal for our sedan to act this way?
Crespo's Avatar
can anyone take some pic for both side of the car?
Old Oct 26, 2007 | 12:03 PM
(>")> G35's Avatar
Can you post the specs of your alignment? My rear at -1.3 was looking kinda tucked and at -0.5 it was pretty flush. Also are you talking about your rears, fronts or both that are not flush? Because if it's the fronts, the 19x8 +35 or +45 offset of those wheels will never be flush, the rears should be at 19x9.5 +40.
Popes
Jul 29, 2015 05:07 PM
RedBaronK
Jul 27, 2015 06:25 PM
Karnicle
Jul 23, 2015 05:08 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
