question for those running coupe 19s on sedan?
Old Oct 28, 2007 | 05:01 AM
black_sedan's Avatar
what tire sizes are you running in the front. i just picked up a set of coupe 19s but the tire sizes are 245/35/19 FRONT and 245/40/19 REAR. Is anyone running 245/35 on the 19s coupe fronts? just want to know if it might rub?
Old Oct 28, 2007 | 05:09 AM
Beebo's Avatar
are you lowerd? it may... correct size should be 225/40/19
Old Oct 28, 2007 | 10:40 AM
GixxerSteve's Avatar
I'm going to be picking up a set of coupe 19's this week, and I was going to go with the stock 225/40 front and 245/40 rear. I've heard the 245/40 will fit up front on stock suspension....not sure about lowered.
Old Oct 28, 2007 | 11:46 AM
CandlestickPark's Avatar
ill Sedan
I'm running Coupe 19s with 245/40/19 front and rear with no rubbing issues on stock suspension. From what I understand from reading other posts, if I do a drop then my rear will rub and I'll have to get my fenders rolled or get a different tire size. Not sure about the fronts, I haven't heard of anyone having any issues up front.
Old Oct 28, 2007 | 11:59 AM
yeah, i believe the reason the 245/35 were used because the tires didnt come in 225/40 so they ran a 35 series. I've got a set of z-springs to go on so i guess ill mount them up and try them on the stock height first and see how much clearance ive got.
Old Oct 28, 2007 | 01:07 PM
ttrank's Avatar
Grocery getter
I know those 19's are pushing it as-is so you might rub.
Old Oct 28, 2007 | 03:11 PM
You are stock suspension, right? Do you have the 8.0 rims front and 8.5 rear? And the 245/40-19s don't rub at all on the front? Thanks.
Old Oct 28, 2007 | 04:00 PM
Beebo's Avatar
he said all the answers in the post.. yes he has stock suspension, stock 19's are 8.0 front 8.5 rear so yes, and he said he doesnt rub
Old Oct 28, 2007 | 05:10 PM
Wow, didn't know Candlestick had a spokesman. I know very well that the Rays 19's are 8.0/8.5, but some sedan owners get 4 of the front rims....I was simply checking with him. Thanks though.
Old Oct 28, 2007 | 06:01 PM
02themax's Avatar
I've got 245/35/19 up front and 245/40/19 in rear lowered on htechs with no rubbing at all. I have never rubbed with these tire sizes even lowered PLUS my tires are all brand new. HTH's. Check my sig below for a photo.
Old Oct 28, 2007 | 06:35 PM
ill Sedan
Yes I am on stock suspension. I have the standard staggered wheel setup for Coupe 19s (8 front, 8.5 rear). I do not rub at all on the front with 245/40/19 tires. I've driven with 4 adults in the car, absolutely no rubbing.
Old Oct 28, 2007 | 07:29 PM
thanks! i was thinking i might have to sell my 245/40s and run 225/35s up front. im waiting to put my 350z springs on and we'll basically twins! are you fenders rolled at all?
Old Oct 28, 2007 | 07:31 PM
Beebo's Avatar
thats right i didnt even think anout that... sorry
Old Oct 29, 2007 | 04:42 AM
No worries.
Old Oct 29, 2007 | 05:23 PM
02themax's Avatar
No, the fenders are not rolled, I thought about it but decided to drop the car first and I have had no problems at all. Get those springs on now!!
