Approaching 100k (Maintenance)
Old Oct 30, 2007 | 12:44 PM
cooldog45's Avatar
Just wanted to know what I should do for the 100k maintenance.
I change my oil every 3k with Royal Purple 5W30.
Just did some FI cleaner.
Had the brake fluid changed.
Changed the rear diff fluid at 60k
Belts changed at 60k
had the tranny flushed at 75k
Debating on changing
coolant
PS fluid
coolant hoses
Am I missing anything?
THx
Old Oct 30, 2007 | 02:08 PM
bythabay's Avatar
coolant
PS fluid
coolant hoses
THx
I've attached the maintenance schedule from the service manual (see attached)
From the above list it seems like you might really be lacking in maintenance. "Changed rear diff fluid at 60k" .. that fluid is supposed to be replaced at 30k.
Old Oct 30, 2007 | 02:09 PM
sloppymax's Avatar
I would advise checking the oil analysis over on my350z. The RP 5w-30 tested to be one of the worst tested oils so far. There are much better performing oils for similar or less money. Have you done the plugs yet? If you are at 100k and not done that or fuel filter then I would definetely put those at the top of the list.
Old Oct 30, 2007 | 08:46 PM
awong's Avatar
SEAFOAM UR CAR ... its cleans out ur engine faster babe =D
Old Nov 1, 2007 | 11:49 AM
cooldog45's Avatar
I bought the car with 50k on it and I changed the plugs then. As for the rear diff fluid it was nice and clean at 60k. I put synthetic fluid in there. I have used seafoam twice already I do it about every 10k. I suck it up through the PCV into the throttle and then she smokes like all hell. As for the oil I was not aware of the RP being bad. Will look into that.
Thx
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
DRG35R
Sep 16, 2015 05:33 AM
