Oil consumption..how to remedy
Old Nov 2, 2007 | 11:09 AM
MEXTEP's Avatar
I am out of warranty and totally neglected the oil consumption issue, so I guess it's up to me to get this fixed.
what can I do to fix this. would rebuilding the engine be enough or do I need a whole new engine?
Since I would be taking the motor apart what can I do to get some more horses out of it but keep it as a good DD. I don't want to go all out but just maybe add some ponies.
I had to neglect this issue because of so many difficult issues going on in my life at the time.
Old Nov 2, 2007 | 11:16 AM
DaveB's Avatar
What year G and how much oil is being consumed every interval? What kind of oil are you using? How often are you changing the oil?
Old Nov 2, 2007 | 11:29 AM
Jeff92se's Avatar
Red Card Crew
You're going to have to determine why the engine was consuming oil. I don't think I've read what the confirmed cause was/is.
Old Nov 2, 2007 | 12:41 PM
black_sedan's Avatar
what year/model do you have?
i thought the only ones with consumption issues were the rev-up motors?
Old Nov 2, 2007 | 12:50 PM
MEXTEP's Avatar
about 2 quarts every 1k..my car is a 2004 sedan. Mobil 1 used always and changed at 4000 intervals.
Edit: forgot to mention..car has around 67K miles
Old Nov 2, 2007 | 02:36 PM
canucklehead's Avatar
the powertrain warranty is 70k miles is it not?
Old Nov 2, 2007 | 07:42 PM
Jason@Riverside's Avatar
wait...........
Old Nov 3, 2007 | 01:25 PM
Ciccio's Avatar
Originally Posted by Jason@Riverside
wait...........
Any reason why? I just came from the dealer and they said they're not replacing any engines anymore.
Old Nov 4, 2007 | 12:25 AM
Tunerz_Store's Avatar
Thats B.S.... they have to honor the warranty. Powertrain is 6yr 70k miles. Take it back, tell them you want an oil consumption test started. Get this ball rolling before the clock hits 70k. For what its worth, I ran mobil one in my wifes spec v which is notorious for burning oil. It would use 1/2 - 1 qt every 3k miles. I switched out to conventional oil, penzoil and doesn't burn anything anymore.
Old Nov 4, 2007 | 01:36 PM
MEXTEP's Avatar
I think I'll pay the dealer a visit if the standard warranty is 70k
Old Nov 4, 2007 | 11:26 PM
this remark highlights the importance of reading your manual. you should have known this.
take it to the dealer before you hit 70k, have them start an oil consumption report. if the problem persists, they are obligated to correct the defect. do not take no for an answer.
Old Jan 9, 2008 | 11:34 AM
AdamJ's Avatar
nm.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
