05 RWD Fuses/Fusebox
Old Nov 6, 2007 | 12:25 PM
trey.hutcheson's Avatar
Last weekend while at the track I removed the Stop Lamp fuse so I could do a burnout. It came flying out and fell inside the fusebox compartment and now I cannot retrieve it. I noticed there was an extra 10amp fuse, so I thought I'd be covered. Wrong. The extra fuse doesn't fit right. I'm not a fuse guy, so I can't exactly explain why it won't fit. I just know the prongs are longer and shaped differently.
I didn't want to leave the track without brake lights, and it's close to 100 miles away. I looked at the fusebox diagram and saw a fuse labeled AWD. I yanked that fuse(10amp) and am now using it in place of the missing 10a Stop Lamp fuse.
So - what is the purpose of this AWD fuse in the RWD vehicles? Am I driving around with some important subsystem now effectively disabled?
Old Nov 6, 2007 | 12:39 PM
express705's Avatar
if its the spare 10A light, it should fit fine. if its the normal size one, let me know.. ive got a few here.. ill throw one in the mail.
just shoot me a PM
Old Nov 6, 2007 | 03:06 PM
ttrank's Avatar
Grocery getter
It should fit fine. Maybe some defect with that fuse.
Old Nov 6, 2007 | 04:38 PM
RADIOGUY21's Avatar
Correct me if im wrong but its probably nothing, my guess is infiniti probably uses the same fuse box along with populated fuses amongst the G35X and G35. There probably isnt any wires terminating at that AWD fuse or a relay is missing somewhere for the AWD system, making that fuse you pulled do nothing but act as an extra 10A fuse. If you had AWD, pulling that fuse would probably disable the AWD system.
As for the extra fuse it was probably defective, they are industry standard, or at least should be.
Old Aug 9, 2008 | 06:31 AM
maliy06's Avatar
returning from the dead, lol,
the fuse is not defected, i had a similar problem not to long ago, 05-06 models have some some fuses different,03-04 models have all the same fuses,
i double checked, i have an 04 and an 06,
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Alex Koss
Oct 29, 2021 12:53 PM
IEMaestro
2nd Gen (V36) Sedan
Oct 22, 2015 09:09 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
user 3748593
Sep 17, 2015 07:19 PM
