Not sure if I want to buy a G35 now!!
Old Nov 6, 2007 | 09:15 PM
Beni B's Avatar
What is the deal with the G35 and the oil consumption problem I hear about in this forum? I want to get a used G35 with no warranty, and I am worried about the engine going out. Give me some advice on this sub ject?
Old Nov 6, 2007 | 09:19 PM
speedracerg35's Avatar
don't understand why you wouldn't buy a 2 or 3 year old g with average miles and still be covered under warranty. to get a car without warranty, you will need to purchase a car that has was delivered over six years ago and have mileage over 70k. is that what you are looking for? otherwise, a used g will still be covered under factory powertrain warranty.
Old Nov 6, 2007 | 09:21 PM
jaspergtr's Avatar
i have no problem at all with my engine...
but i may not be a good point of reference. have only owned for 49 months w/23k miles. it is not necessarily a global problem, but more or less a specific problem. nothing a monthly oil check can't prevent (which is a part of preventative maintenance anyway).
Old Nov 6, 2007 | 09:23 PM
abailey269's Avatar
I have read that too. However, i can tell you that my motor consumes NO oil and it sees upper rpms often. No sure why others are having issues. EVERY car you will look at buying will have its own problems, no matter the make. This motor is known to run 200+ K miles if taken care of. I wish you luck with whatever car you decide to get, G or not.
jaspergtr's Avatar
wow, i got ripped off!!! my factory warranty was only good for 4 years or 60k miles. your factory was better.
Old Nov 6, 2007 | 09:24 PM
snavematt's Avatar
just a sedan
no problems with mine, and I drive in mad traffic and when its open, I open it up
Old Nov 6, 2007 | 09:26 PM
i know 06's were 6 year 70k miles, i'm fairly certain 05's were the same. anyone confirm?
i spoke with my service manager about this issue, and his belief was that many of the consumption issues may be caused by owners switching to synthetic oil before the rings had the opportunity to seat properly. anyone have an opinion on this?
Old Nov 6, 2007 | 09:28 PM
ptviperz's Avatar
I have two 3.5's and neither of them burn a drop
jaspergtr's Avatar
03-04's were 4yr/60k miles (or so, maybe 64k - i'm not sure because that did not apply to me @ 23k). that would make any 03, 03.5 and early 04's or higher mileage 04's out of warranty, and an attractive buy.
Old Nov 6, 2007 | 09:30 PM
alphamatt's Avatar
i work my g, every time im in it, no problems thus far, in fact i think the g is a really strong ride, ive done some silly stuff, hit hard bumps, potholes.
pjames's Avatar
i just bought a 2003 sedan (well, 4 or 5 months ago), i've still 60000km to go on the factory warranty, (or until next august).
basically the only way you will find one off warranty will be because of mileage, and i don't think you want to be buying a high mileage car.
the oil consumption problems seem to be limited to the '05 and '06 models, and usually manifested quickly (within first few thousand miles), if the car is at 30 or 40k km and is not consuming excessive oil, it's not likely that it will.
Old Nov 6, 2007 | 09:34 PM
snavematt's Avatar
just a sedan
60k, heck I got mine in January with 38k on it, and I got an extended warranty to 98k for cheap (from an Infiniti dealer) Yes, full warranty
Old Nov 6, 2007 | 09:38 PM
dickersonka's Avatar
Had no problems with my g, bought it 3 years old and am up to 35k on it now. Not quite sure you want to get it with no warranty, unless buying used and past that mark. You can get a used one for just a little bit more still under warranty, than one thats not. Don't necessarily worry about the engine oil problem that some experience. I had a cd player issue, which Infiniti took care of completely. Nothing wrong with the g's, just consider like you would anything else, a little money now will mean a lot more in the long run. Spend the extra 50-100 its saving you a month to get an out of warranty g and anything that comes up will be fixed for another couple years, well worth the little cost in the meantime.
Old Nov 6, 2007 | 10:38 PM
maximumvette's Avatar
yes, 05's are also 6year 70k.
Old Nov 6, 2007 | 11:43 PM
Beni B's Avatar
The G35 I want to get is a 2003 with 49000 miles. I can get it for $15000 out the door. I am looking for a car that is a little used for work and don't want to spend more money. I just hope I don't have any major engine problems!
