Windshield rattle
Old Nov 17, 2007 | 10:53 AM
blownvert's Avatar
Windshield rattle
Ok i have a 04 g35x, just had warranty with the compression rods going out. Now I have noticed that now since yesterday i have this windshield rattle noise coming directly in front of me in the windshield. I pressed on other things but it really is the windshield. How do i stop that noise? Its so annoying. When i am driving all day any speed a little higher because more vibration all it does it rattle. The right rear window has rattle also but only when i like stop the brakes and then press the gas a little again, i can here creaking. Why is that? I had that before the windshield problem. Will warranty cover it?
Old Nov 17, 2007 | 11:53 AM
Konsole's Avatar
I just noticed that one of the little clips on the right side cowl grille was broken and seems to be rattling against the windshield. When I removed the battery cover and the right cowl grille it doesnt make the rattle.
i have another rattle up there also, but i havent found it yet. I dont think its the left side cowl grille.
Old Nov 17, 2007 | 12:11 PM
Gilley's Avatar
The buttons on the Homelink mirror can rattle too.
Old Nov 17, 2007 | 06:17 PM
blownvert's Avatar
I am putting my ear up to the windshield and it really seems like it is the windsheild. the noise wont go away and it is kind of loud. cowl grill on side of car? i pressed my hand on all the vents up there and didnt make a difference.
Old Nov 18, 2007 | 10:48 AM
blownvert's Avatar
bump
Old Nov 29, 2007 | 09:15 PM
Beni B's Avatar
I don't know what the noise you are experiencing is. However, I hear a rattling noise as well. When the vehicle is stopped there is no noise, as soon as I excelerate I hear a noise in the back of the car (right and left side). I think it's coming from the back doors. It's annoying the crap out of me, and I'm ready to throw the car off a bridge. This noise happens when the car moves from giving it gas. When I drive at a steady rate of speed, there is no noise. Anybody else experiencing this?
Old Nov 29, 2007 | 09:55 PM
daveblank's Avatar
Grab the rearview mirror & giveit a light squeeze & see if the noise stops. It's a common problem. I've heard of some people taking the mirror hales apart & insulating the noise but I just replace it if it's under warranty.
Beni B, try lowering your rear windows 1 inch. If the noise goes away search for the rear window bolt bulliten.
Old Nov 29, 2007 | 11:22 PM
Konsole's Avatar
I replaced my passenger side cowl grille and that fixed most of it. The mirror doesnt make any noise on mine.
I think I might get that compression rod crack/click sometimes but this other rattle was pretty constant and the cowl grille was the culprit
Old Dec 1, 2007 | 09:13 AM
Beni B's Avatar
I lowered my rear widows on both sides, on one side the creaking noise stopped.
The problem was coming from the rear doors. I will take to the dealership now and they can correct the problem. Thanks daveblank!
Old Dec 6, 2007 | 09:12 AM
blownvert's Avatar
how do you know it came from doors?
Old Dec 6, 2007 | 12:56 PM
jimmyc13's Avatar
Sounds like it's your cowl, that's what mine was. There is a TSB for this common problem....very common in colder weather too.
Old Dec 6, 2007 | 06:19 PM
blownvert's Avatar
The rattle went away when i pulled the wipers up and put them back down. I dunno now all that is rattling is my right rear window
Old Dec 7, 2007 | 11:58 PM
IP05G35's Avatar
The window rattle is because of the bolts inside the window motor, take it to the dealer and they will fix it. Mine was doing the same thing.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
