My G35 Pics ! Plus Dual Xenon Install
Old Nov 23, 2007 | 05:05 PM
Rodrigo's Avatar
My 03.5 G35
I joined the forum a few weeks ago but i came over from the sr20forum, so i have my fair share of knowledge of Nissans.
I took some pics and Today and did a dual xenon retrofit.
I took some Maxima Xenon bulbs and ballast with ignitors and removed my stock hallogen bulb and installed the maxima xenon in there. the fit was snug but drilling in 3 screws aroun d the sides to bolt it down worked wonders.
about a 3 hour install to do it right. here ya go.
another
http://i151.photobucket.com/albums/s...r/PICT0034.jpg
side
http://i151.photobucket.com/albums/s...PICT0022-1.jpg
interior
http://i151.photobucket.com/albums/s...PICT0019-1.jpg
Old Nov 23, 2007 | 05:10 PM
GixxerSteve's Avatar
Clean 03.5! Just wondering, it looks like the stock reflector headlamps, so did you just install HID on your factory headlamps? Or did you retrofit projectors?
Old Nov 23, 2007 | 05:12 PM
patman530's Avatar
^^ those pics don't really show any part of the "retrofit" that was done.
Old Nov 23, 2007 | 05:25 PM
Rodrigo's Avatar
HID instal
here is a DIY pics.. remove the grill and wheel , thw wheel well splash gaurds by poping out the screw clips and 5 bolts under splash gaurd
next romve the wheel well fender cover
http://i151.photobucket.com/albums/s...PICT0017-3.jpg
remove old bulb and cut its harness you need to rewire it .
Yellow is power and red is high beam and the black is ground.
http://i151.photobucket.com/albums/s...PICT0018-1.jpg
next wire the red plug from the hid to the factory yellow and black to black. refer to pic
http://i151.photobucket.com/albums/s...r/PICT0020.jpg
next test for power
http://i151.photobucket.com/albums/s...PICT0016-1.jpg
after it lights up Dual Xenon , with out retro fiting projectors.
http://i151.photobucket.com/albums/s...PICT0021-1.jpg
another
http://i151.photobucket.com/albums/s...PICT0022-2.jpg
and 1 more
http://i151.photobucket.com/albums/s...r/PICT0023.jpg
i will post some night ones later
Old Nov 23, 2007 | 05:32 PM
patman530's Avatar
i see...so you retrofitted maxima d2r xenon bulbs, ballasts, igniters into the stock fog/high halogen bulb housing.
nice job, it should improve your visibility, especially with high beam on. having the fogs on with the low beam will probably cause significant amounts of glare for oncoming traffic though, since the housing wasn't designed for HID light output.
Old Nov 23, 2007 | 05:34 PM
Rodrigo's Avatar
thats correct my friend,
can some one fix my links so that the show the pics please.
Old Nov 23, 2007 | 05:38 PM
patman530's Avatar
Old Nov 23, 2007 | 05:44 PM
Rodrigo's Avatar
Thanks ,
you da man
Old Nov 23, 2007 | 05:53 PM
Wannabe6MT's Avatar
-MN G Crew-
Clean G man! Looks like mine minus the X and yours is black!
Old Nov 23, 2007 | 05:55 PM
Rodrigo's Avatar
Night Time
Damm these things are bright
Old Nov 23, 2007 | 05:58 PM
Wannabe6MT's Avatar
-MN G Crew-
Looks great man. How much did all this cost you?
Old Nov 23, 2007 | 05:59 PM
Rodrigo's Avatar
^ $100 for the set and my time and a few screws i had laying around the tool box
Old Nov 23, 2007 | 06:05 PM
Wannabe6MT's Avatar
-MN G Crew-
Thats one helluva bargain.
Congrats man. Looks fantastic!
Old Nov 23, 2007 | 06:30 PM
Rodrigo's Avatar
Thanks man !
I wanted to put the projector in there but that would have cost alot more.
Old Nov 23, 2007 | 08:18 PM
Rodrigo's Avatar
Now i need a 04 350z suspension.
